Max spring rate
im assuming this is for a track car.....
why dont you tell us the spring rates and how much you want to change suspension travel, and then we tell you wether or not normal koni yellows can take it....
in general, yellows can take most anything...spring rates arent what kills shocks as much as changing the rate of travel and wear on the shock by lowering it
why the hell are they so stiff in the rear?? are these custom rates from GC???.....yellow's should hold up fine on those....but if they are GC, get the ones that are made to work with each other.....
Guest
Posts: n/a
alryte, before i go on, i dunt wunt u to read this the wrong way im not trying to offend u(cuz alota people here r short tempered bitches with sand in their vagina)...why so high in the back?? how much do u kno about choosing custom spring rates, im not questioning your knowledge but, it just seems ridciously high to me, i never seen a FWD(or a RWD) with rear springs higher then the front...but maybe ur a real knowledgable guy that knows his shyt and thats wut u wunt, *shrugs* but please do tell me why u chose the spring rates that u did
sigh, some people dont know what they're talking about
in a fwd, if your rear is stiffer than ur front, it will be easier to rotate the car in turns.
lots of autox's and road racers run extremely stiff rears..they go up in the 1200's+ when their fronts are like 600-800. sure, you can get a front of 800 and a rear of 500. have fun with understeer.
to ansewr your question, those koni's will handle your rates fine. the yellows should be able to handle higher rates without getting revalved too.
im on 350/450 on kyb agx's. the agx's dont dampen enough tho :\
To be completely honest, I don't know jack about rates, I just know that the lower the # the softer and the higher the stiffer. If the KONI's can handle 400-600 stock with a 2.25-2.5 drop without any problem then there's no point in talking about this until I'm about to order my ground controls...thanks
Modified by Corruption at 10:20 AM 2/10/2006
20CiviC02Si
18
May 30, 2012 10:18 PM
internet ay
14
Apr 4, 2002 08:44 PM
