Trick my ECU into fixing my timing ???????
Old May 17, 2005 | 12:54 PM
ApolloSpeed's Avatar
Default Trick my ECU into fixing my timing ???????
On my 94 Del Sol B16 (Stock, only CAI, HighFlow Cat)
I swapped DIzzys with a friend to check a problem a while back....then put mine back on....
Since then, my timing has been slighty retarded at idle (maybe a degree or two), and my dizzy will not turn anymore to advance it.
So, can I turn my dizzy the other way to "Seriously" retard the timing, then unplug the battery to reset the ECU....had have the computer fix my timing ?
or will that not work ?
Old May 17, 2005 | 06:58 PM
Hurricane's Avatar
Default Re: Trick my ECU into fixing my timing ??????? (ApolloSpeed)
No
downeyballz
Jun 9, 2007 09:47 AM
smash fascism
17
Sep 14, 2005 07:02 AM
ApolloSpeed
May 19, 2005 11:27 AM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
