h22 swap done - but no power from 1k-3k rpms! HELPPP
Old May 17, 2005 | 12:37 PM
volklude's Avatar
Default h22 swap done - but no power from 1k-3k rpms! HELPPP
Hey guys, after too long i finally got my car up and running after throwing in an automatic jdm h22. everything is running fine the only problem is it feels as if it is very short of power in low rpms. as the rpms start to climb so does my power. anyone experience this? any suggestions? kinda ruining my swap fun
thanks guys
James
Old May 17, 2005 | 12:53 PM
IHateJDM's Avatar
Default Re: h22 swap done - but no power from 1k-3k rpms! HELPPP (volklude)
if you are missing power in a certain (high or low) rpm band, its usually timing related. put a timing light on it.
Old May 17, 2005 | 02:11 PM
Greyout's Avatar
Default Re: h22 swap done - but no power from 1k-3k rpms! HELPPP (IHateJDM)
I'll bet a cam is one tooth off... specifically, the exhaust cam is retarded by a tooth (just a guess)
Old May 17, 2005 | 03:18 PM
volklude's Avatar
yeah thats what my dad suggested...that the timing might be off...could anyone be more specific on how to correct this?
Old May 18, 2005 | 05:05 AM
IHateJDM's Avatar
Default Re: (volklude)
take the timing belt off. set the crank and cam gears to tdc, put belt back on, tighten tensioner. get timing light. jump 2 pin connector by ecu. clip light to plug wire 1. shine light on service hole in tranny at flywheel. line up the mark on the tranny housing with the mark on the flywheel by turning the dizzy. tighten dizzy in correct position.
ShinobiLude
Dec 7, 2006 10:23 AM
deucedeuceEK
Dec 1, 2006 10:49 PM
ds2000
Nov 22, 2005 12:50 AM
3rdGteg
Oct 31, 2002 09:58 PM
