CBR Battery problem
Old May 17, 2005 | 12:15 PM
denboy's Avatar
Default CBR Battery problem
I have had some problems with my battery lately. People have been telling me that I should go get a new battery. But before doing so, I've decided to give it a good charge and go from there. The battery has been sitting in the bike for the whole winter and in addition i didn't charge it before taking it out. Is it necessary for me to get a new battery? How do you tell if the battery is dead? I'm riding a 2002 cbr f4i and the battery is stock. Please give me some advice.
Old May 17, 2005 | 12:20 PM
85's Avatar
85
Default Re: CBR Battery problem (denboy)
If you have some form of a Voltage meter and have not charged it yet try this... Is the voltage higher or lower then 9.6V? it > then the bat may be ok. if lower, its gone. I would give it a shot, charging it, but for a couple of days riding don't ride too far, and pay close attention to the bike when its starting. if it starts cranking slower then normal i would dump it before you get stranded
Old May 17, 2005 | 01:14 PM
cbrman's Avatar
Default Re: CBR Battery problem (hks85)
Have it load tested. After charging it, put a load on the battery (starter would be a good test) and have the voltage tested. If the voltage drops drastically say less than 10 volts while the starter is engaged then it is bad.
Most auto parts stores will load test the battery for free. That is really the best way to test the battery.
Good luck.
Steven
Old May 19, 2005 | 02:22 PM
85's Avatar
85
Default Re: CBR Battery problem (cbrman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbrman &raquo;</TD></TR><TR><TD CLASS="quote">Have it load tested. After charging it, put a load on the battery (starter would be a good test) and have the voltage tested. If the voltage drops drastically say less than 10 volts while the starter is engaged then it is bad.
Good luck.
Steven</TD></TR></TABLE>
i forgot to mention that
welder
Honda Ruckus and Scooters
Aug 24, 2023 08:52 AM
Eg6_rAcEr
Honda Motorcycles
Jul 23, 2005 05:26 PM
denboy
Honda Motorcycles
May 18, 2005 12:25 PM
ee-gsr
Honda Motorcycles
Oct 17, 2004 10:53 AM
cbr600jefF2
Honda Motorcycles
Dec 20, 2002 05:30 AM
