Front Sway bar on VX?
Old Feb 5, 2002 | 11:45 AM
OR-G's Avatar
Default Front Sway bar on VX?
I doubt there is, but I'm just wondering if they do come on the VX?
Since they probably don't, can anyone recommend a good front sway bar? (Not mugen as mucho $$$).
Old Feb 5, 2002 | 11:50 AM
Spade's Avatar
Default Re: Front Sway bar on VX? (OR-G)
99-00 Civic SI (26mm)
Old Feb 5, 2002 | 03:05 PM
BERT-O's Avatar
No, they don't. Only in the 92-95 Civic SI/Ex. I believe is a 22mm, but i forgot. However, I have one install in my '94 h/b CX. I only bought the lower arm from a civci si/ex,>> swap out the lower arm (cause it has the opening hole for the swap endlinks to be mounted on)and get all the hardware (endlinks, boths, D-bracket, and bushing)it will bolt up to your undercarraige. About 30min or so if you do it on a lift. Its well worth it, believe me. I do advise to do the rear sway from the ITR.
Again, factory parts are the best fit. Donno about the aftermarket ones, though!
EdSales
Aug 7, 2009 12:44 PM
cambokid
May 5, 2008 07:44 PM
SoullessJapaneseMachine
Suspension & Brakes
Oct 10, 2007 07:43 PM
2.3lcivic
Sep 27, 2007 09:46 AM
PARADOX_sf
Suspension & Brakes
19
Jan 10, 2007 01:40 PM
