ABS ECU interchangability - 97 -> 98-01
Old May 17, 2005 | 10:00 AM
D's Avatar
D
Default ABS ECU interchangability - 97 -> 98-01
anyone know of any difference between 97 ITR and 98+ ITR ABS ECU? I'd guess they would be interchangable, afaik ABS modulators are the same for all years ITR, changes for GSR at MY 98. Any additional info appreciated.
97 ITR ABS ECU pn 39790-ST7-A11
98-01 ITR ABS ECU pn 39790-ST7-A31
and for reference
97 GSR ABS ECU pn 39790-ST7-A02
98-01 GSR ABS ECU pn 39790-ST7-A21
D
Old May 17, 2005 | 11:24 AM
Chris F's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">anyone know of any difference between 97 ITR and 98+ ITR ABS ECU? I'd guess they would be interchangable, afaik ABS modulators are the same for all years ITR, changes for GSR at MY 98. Any additional info appreciated.
and for reference
D</TD></TR></TABLE>
I have no idea. Maybe someone with a clue will read the post.
Old May 18, 2005 | 04:14 PM
D's Avatar
D
Default Re: ABS ECU interchangability - 97 -> 98-01 (Chris F)
alright, apparently 94-97 GSR/LS ABS ecu's were larger, and manufactured by NEC, the 98+ were smaller, and manufactured by nissin.
however, the 97 ITR ABS ECU is the newer variant, manufactured by nissin. So, does anyone know any differences between any of the newer nissin units? 97 ITR, 98+ITR, 98+GSR/LS??????
D
edit - 97 ITR ABS box got rid of all my ABS codes, however, i have yet been able to engage abs.
Old May 18, 2005 | 05:29 PM
uNF$@#!'s Avatar
step on the brakes real hard
Old May 19, 2005 | 11:06 AM
Chris F's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 &raquo;</TD></TR><TR><TD CLASS="quote">step on the brakes real hard </TD></TR></TABLE>
Yeah,
ABS braking is for sissies.
[this isn't a bump]
Old May 19, 2005 | 11:09 AM
norice's Avatar
The 1997/1998 ECUs had different harness pinouts than the 2000+ ECUs. With an OBDIIa/b conversion harness, they are interchangable.
Old May 19, 2005 | 11:12 AM
Chris N's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (norice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norice &raquo;</TD></TR><TR><TD CLASS="quote">The 1997/1998 ECUs had different harness pinouts than the 2000+ ECUs. With an OBDIIa/b conversion harness, they are interchangable.
ps. i dont ready before i post</TD></TR></TABLE>
Uh. ABS ECU?
Modified by Chris N at 2:33 PM 5/19/2005
Old May 19, 2005 | 11:19 AM
D's Avatar
D
wow, and to think i was expecting something useful to be added to this post.
Old May 19, 2005 | 12:08 PM
typer_801's Avatar
My only suggestion is to have some of the folks at Expo compare them since they'll likely be 97's and 98+ ITR's in abundance. I'm sure someone could snap some photos, see if the harnesses are identical, etc.
Old May 19, 2005 | 02:21 PM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D &raquo;</TD></TR><TR><TD CLASS="quote">wow, and to think i was expecting something useful to be added to this post. </TD></TR></TABLE>
It's your own fault, you only said ABS once in the title and only 6 times in the body.
Old May 19, 2005 | 04:53 PM
Tweakmeister's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (Dave-ROR)
Did someone say "abs" ?
Old May 19, 2005 | 05:33 PM
onePOINTsix's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (Tweakmeister)
^^^ yummeh! We were trying to figure this out last week... i wonder is CanuckR will let us "borrow" his ABS ecu and throw is into another R
Old May 19, 2005 | 05:41 PM
sackdz's Avatar
Default Re: ABS ECU interchangability - 97 -> 98-01 (typer_801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">My only suggestion is to have some of the folks at Expo compare them since they'll likely be 97's and 98+ ITR's in abundance. I'm sure someone could snap some photos, see if the harnesses are identical, etc.</TD></TR></TABLE>
they're a PITA to get to though. wish i could help you out D but i have a 97 as well. TTT
Old May 19, 2005 | 07:44 PM
D's Avatar
D
Default Re: ABS ECU interchangability - 97 -> 98-01 (sackdz)
thanks... finally some good content here. apparently i'm also having problems with my TNA ECU........
just to rehash, i have the 97 ITR ABS brain in my 98 now, cleared up all my codes. and from the 97 ITR supplement, there appears to be 1 extra wire called out on the 97 ITR 22P orange connector, shrug, apparently a additional ground.... but it's also kinda called out in the 98 manual. (1 schematic, but not the pinout) shrug... whatever.
BTW... Len, if you see this..... can you check part interchange on the acura parts software... my copy doesn't give me the ability.
Old May 20, 2005 | 02:32 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norice &raquo;</TD></TR><TR><TD CLASS="quote">With an OBDIIa/b conversion harness, they are interchangable.</TD></TR></TABLE>
yeah D....fuggin dumbass.
Old May 20, 2005 | 03:09 AM
Back in Black's Avatar
Rather OG
Default Re: ABS ECU interchangability - 97 -> 98-01 (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote"> yeah D....fuggin dumbass.</TD></TR></TABLE>
Yeah.
Black R
Oct 24, 2012 06:22 AM
D
Jun 3, 2005 11:04 AM
Bnjmn
Sep 15, 2003 03:42 PM
yaksplat
Aug 23, 2001 08:42 AM
