What is wrong with this picture???
PART LABOR
5030-FI-C Direct Port custon install $ 595.00 $350.00
Soft Plume Nozzle Upgrade $ 40.00
Custom Manifold Plumming $160.00
Remove/Install Intake Manifold $125.00
16030 Purge Kit $ 95.00 $90.00
16058 Remote Bottle Opener $160.00 $90.00
14164 Bottle Heater $115.00 $90.00
Bottle Wrench $11.00
4AN Tee Fitting $9.00
3AN 90 Degree $8.00
4AN 4ft Line $21.00
4AN 6ft Line $28.00
Activation Button $42.00 $25.00
Holley 255lph Fuel Pump $165.00 $80.00
MSD Digital 6 $280.00
MSD Window Switch $75.00 $45.00
MSD 3000/8000 RPM kit $25.00
MSD Coil $39.00
MSD Distributor Cap $35.00
MSD Wire Set $65.00
Ignition System custom installation $160.00
Autometer Gauge Pod $50.00 $25.00
3363 Autometer Fuel Pressure Gauge $180.00 $75.00
3375 Autometer A/F Gauge $50.00 $50.00
3328 Autometer Nitrous Gauge $70.00 $50.00
Autometer Tachometer $50.00
Tachometer Light Bulb $2.00
30A Relay (2) $8.00
Misc. wire/fuse holders $25.00
System Switches $59.00
Spark Plugs $7.50
Intake Manifold Gasket $9.00
1 Gallon AntiFreeze $5.00
TOTAL $2,273.50 $1,465.00 =$3,738.50
Sales Tax $187.57
GRAND TOTAL $3,926.07
Where is this wrong, because I know something can't be right!
Jon
3AN 90 Degree $8.00
4AN 4ft Line $21.00
4AN 6ft Line $28.00
MSD Coil $39.00
MSD Wire Set $65.00
30A Relay (2) $8.00
Spark Plugs $7.50
Sales Tax $187.57
Jon
i'm surprised with how big that list is.....that they didn't charge you for a number 1 at mcdonalds and the toilet paper to wipe up afterwards
Lip,
What on the list did they charge me for that they should not NORMALLY be charging me for?
Doesn't that price on the Fuel Pressure Gauge seem abnormally high? I thought they were like $100?
Thanks,
Jon
Thanks,
Jon
Is the labor well over what it should normally be, or just a bit? I want to know if it is just a bit higher because he does nice work, or if he is trying to f*ck me making it outrageously higher.
Jon
Jon
as they said...it IS alot of wiring. If they do good work...its worth the extra buck or 2....just knowing they are doing it right.
your getting ripped dude. . . . i can get the whole direct port upgrade kit for about $250 for everythin from summit . . .
do you already have n20 and upgrading it?
let me know , ill get you in the right direction , cuz im upgrading mine now and got part #'s and poo poo
It is my BILL, but I could still negotiate a bit I HOPE! He told me the other day that he could cut it down to $3500... .should i ask for even lower, or would that be very rude? I was thinking of giving him $3500 and asking him to install a dash kit and a custom purge outlet for that price of $3500 is that unreasonable of me?
Jon
Jon
I did agree on a price for a dry system of 2050 with all of the same upgrades as I have for the Direct Port setup included. The only thing I added was a fuel pump and a direct port upgrade and soft plume nozzles. So I figured I could afford the direct port upgrade.. .I had no idea it would be this much though.
Jon
Jon
Drinker
