Humming/whining sound from left dash area...
Old May 16, 2005 | 09:10 PM
8point6's Avatar
Default Humming/whining sound from left dash area...
I recently purchased a 92 Civic SI hatchback and am experiencing a humming/ whining sound which is coming through the driver's dash area on the left hand side of the steering wheel. This noise get louder as the engine rpm's get greater. I thought it may have been the alternator, but am unsure.
Any help is appreciated.
Old May 16, 2005 | 09:36 PM
carlosd68's Avatar
do u have an amplifier? lol when those ***** are messed up they make a humming noise when u accelerate
Old May 17, 2005 | 09:01 AM
8point6's Avatar
Default Re: (carlosd68)
It doesn't sound like air and I removed my amp awhile back when troubleshooting this problem. The noise is still present without the amp.
I know the noise is NOT from:
Intake
Tweeters
I recently installed a JDM cluster, has anybody ever experienced abnormal humming sounds from theirs?
Old May 17, 2005 | 03:23 PM
crvtecwidebody's Avatar
Default Re: Humming/whining sound from left dash area... (8point6)
pgm-fi relays make stupid noises. It is located under the dash and to the left of the steering wheel.
Just an idea.
Old May 17, 2005 | 06:53 PM
8point6's Avatar
Default Re: Humming/whining sound from left dash area... (crvtecwidebody)
I'll check this out, any other ideas?
Old May 17, 2005 | 07:42 PM
drevinder's Avatar
is the noise only coming when ur driving.? .if so could be wheel bearing....
Old May 17, 2005 | 07:48 PM
civicboisi's Avatar
Default Re: Humming/whining sound from left dash area... (drevinder)
^ that or tires...
Old May 17, 2005 | 08:16 PM
8point6's Avatar
Default Re: Humming/whining sound from left dash area... (civicboisi)
I do have Azenis tires, but I'm familiar with that certain noise. This noise sounds electrical. My ears just can't pinpoint its origin though.
Old May 17, 2005 | 11:08 PM
8point6's Avatar
The noise is present whenever the throttle is depressed, even at a standstill in neutral while revving. The noise increases as the revs raise.
Old May 24, 2005 | 11:08 PM
8point6's Avatar
still haven't figured this out...
Old May 25, 2005 | 04:59 AM
AlpineInstaller's Avatar
Your problem is electrical noise. Something is not grounded right and/or not shielded correctly/adequately. This noise can be amplified through any of the speakers in your car. You may also notice that your noise increases or changes pitch when the windshield wipers turn on, or when your turn signals are on.
Old May 25, 2005 | 05:15 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Humming/whining sound from left dash area... (AlpineInstaller)
Wheel bearing on driver's side.
Old May 25, 2005 | 05:26 AM
Default Re: Humming/whining sound from left dash area... (CTU litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTU litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearing on driver's side.</TD></TR></TABLE>
Can't be if he isn't moving...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8point6 &raquo;</TD></TR><TR><TD CLASS="quote">The noise is present whenever the throttle is depressed, even at a standstill in neutral while revving. The noise increases as the revs raise.</TD></TR></TABLE>
Old May 25, 2005 | 05:32 AM
litterbox's Avatar
Oops, it's early, I must've scanned over that. My bad.
Old May 25, 2005 | 04:13 PM
8point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlpineInstaller &raquo;</TD></TR><TR><TD CLASS="quote">Your problem is electrical noise. Something is not grounded right and/or not shielded correctly/adequately. This noise can be amplified through any of the speakers in your car. You may also notice that your noise increases or changes pitch when the windshield wipers turn on, or when your turn signals are on.</TD></TR></TABLE>
I currently have no audio components installed in the car, not even a head unit. Could be a grounding issue though.
Old May 26, 2005 | 05:14 AM
No speakers?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8point6 &raquo;</TD></TR><TR><TD CLASS="quote">
I currently have no audio components installed in the car, not even a head unit. Could be a grounding issue though.</TD></TR></TABLE>
Old May 26, 2005 | 09:47 AM
8point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlpineInstaller &raquo;</TD></TR><TR><TD CLASS="quote">No speakers?</TD></TR></TABLE>
Nope, no audio components!
Old May 27, 2005 | 05:06 AM
Have you figured this out?... I have been racking my brain trying to think of what CAN make a noise in the dash... there shouldn't be anything in the car that produces that noise (but obviously is!!! ) Have you gotten outside of the car and accelerated the motor? When you are outside, does it sound like it's coming from under the dash or under the hood?... Does it sound the same? If you hear it when under the hood, can you pinpoint it's location? Keep us posted. If you figure this one out, it could save someone else a LOT of time later on if they have the same problem...
Old May 27, 2005 | 09:54 AM
8point6's Avatar
I'm going to try and get a clear audio sample posted of the whining.
Old May 1, 2014 | 03:28 AM
kr33p's Avatar
Sorry to bring this back from the dead. But my car is doing exactly this. Just started today.
Can anyone help me out here?!
Old May 1, 2014 | 04:11 AM
kr33p's Avatar
Wanted to add, I popped the hood and the sound was actually coming from the power steering pump.
Anyone else experienced this? Would I have to replace the pump entirely or try the seals first?
1998 honda civic ex here.
WIhondas
Honda CR-V & Element
Jul 29, 2013 04:58 AM
Choy
Jul 1, 2009 09:50 AM
ice11honda
Sep 2, 2004 12:45 PM
pyromaster
May 27, 2004 07:54 PM
gucci_typer
Jun 24, 2003 03:58 AM
