power mirror's messing up help
Old May 16, 2005 | 07:04 PM
byronl's Avatar
Default power mirror's messing up help
hi, when I try to adjust the power mirrors with the switch it would move to a direction. But if i move more on that same direction the mirror would get stuck and jump back. Should i replace the mirrors itself? or is it a switch problem. thx.
Old May 16, 2005 | 07:28 PM
green-'s Avatar
Default Re: power mirror's messing up help (byronl)
Are you sure you haven't adjusted as far as it can go?
Old May 16, 2005 | 07:45 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">hi, when I try to adjust the power mirrors with the switch it would move to a direction. But if i move more on that same direction the mirror would get stuck and jump back. Should i replace the mirrors itself? or is it a switch problem. thx.</TD></TR></TABLE>
You are adjusting it as far as it can go. Stop it. All your doing is forcing the gear to jump or pop over and then the mirror snaps back. If the mirror is working then leave it alone. Sounds like your just over adjusting it.
Old May 16, 2005 | 07:53 PM
byronl's Avatar
the thing is that I'm not even adjusting it as far as I can get it to.
Old May 16, 2005 | 07:56 PM
HATCHingMN's Avatar
Default Re: (byronl)
pop it open and find out, what's causing it
Old May 16, 2005 | 08:03 PM
byronl's Avatar
Default Re: (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">pop it open and find out, what's causing it</TD></TR></TABLE>
how do i open it? do i just pry it out?
Old May 16, 2005 | 08:10 PM
TallAssFilipino's Avatar
If for example, you are adjusting your passenger-side mirror outward and it's jumping back when it isn't far out enough, just adjust the mirror inward until it jumps back, then start over and adjust the mirror outward again.
Old May 16, 2005 | 08:16 PM
HATCHingMN's Avatar
on the inside of the door behind the mirror, there's a balck cover just pry it out and you should see three locking nuts, just unbolt them. The mirror should come off if you pull it. The inside of the mirror house consist of the motor that power the power mirror. Just loosen the screws on the bottom and the mirror should come off ...then go from there and look for the probelm.
ef_zcvtec
Jun 4, 2007 12:29 AM
StillGotIt
Dec 3, 2006 10:17 PM
Dark_Ferio
Nov 28, 2005 06:31 AM
qat727
Sep 14, 2005 12:07 AM
