EF + B18 = hard??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">search please think of the bandwidth</TD></TR></TABLE>
can't seem to find the diffrences....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">Convert to obd0 - obd1, tranny kit from hasport .</TD></TR></TABLE>
wrong on both but good try, thats optional not needed. *you dont need to run gsr tranny any B will bolt up if you use a cable one no tranny kit needed*
you can run a pr3 i've seen it but yea it sucks. converting to obd1 or 2 is better.
i happen to like my cable trannys so i kept it. hydro is just for sissy legged girly men
the difference is the EF engine bay is smaller. and theres more parts to buy to do it right.
<u>SEARCH:</u>
With Archive Checked:
» Search Results
Your search for b18c returned 882 results.
With Recent Checked:
» Search Results
Your search for b18c returned 112 results.
^^^^dude. the info is readily available. its free.
<u>SEARCH:</u>
» Search Results
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">wrong on both but good try, thats optional not needed. *you dont need to run gsr tranny any B will bolt up if you use a cable one no tranny kit needed*
You know the hasport kit just turns the hydro trans into a cable one right? So your comment isn't valid.
</TD></TR></TABLE>You know the hasport kit just turns the hydro trans into a cable one right? So your comment isn't valid.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink »</TD></TR><TR><TD CLASS="quote">
<u>SEARCH:</u>
» Search Results
» Search Results
^^^^dude. the info is readily available. its free.</TD></TR></TABLE>
ok, first of all i was searching things like "b18 in EF" because the point of "searching" is to find something relevant to the info im looking for and not spending an afternoon looking through all theese files, so i gave it a refined search and came up empty-handed.
secondly, thanks for the line of info but can you be a little more specific as to what i need? (i have the money for a car + a swap, but the EG's arent flooding the market for now, the EF's are) but i don't know if the cost for theese "extras" will be worth it.
Thanks,
TL
<u>SEARCH:</u>
» Search Results
» Search Results
Thanks,
TL
Its pretty easy, but a number of things have to be addressed.
1st decide on whether you are going to use the hydro tranny with the Hasport conversion, or trade it up for a good cable tranny like a YS1. You'll need a mount kit, axels, shift linkage, rad hoses, throttle cable, and if you going obd1 (which you should) you need a wire harness adaptor. Some wiring is needed regardless.
An EG required most of the same parts, but you won't need mount kit, harness adaptor, or have to worry about install of the hydro tranny.
my motor will be one pulled out of a 91 LS
which includes:
Motor(block + internals, head + internals, valve cover etc)
axles
tranny (5-SPD)
ECU
wiring harness
so i duno what the parts are called but its all OEM
which includes:
axles
tranny (5-SPD)
ECU
wiring harness
LSej1
Feb 20, 2008 05:00 PM
92-LS-Civic
22
Jan 9, 2005 07:29 AM
crazyass05
May 21, 2004 09:35 PM
