Dash clock??
Old May 16, 2005 | 06:43 PM
EtchaSketch's Avatar
Default Dash clock??
This is on a 92 civic Si Hb
I dont know what happend, but my dash clock is dead. It lights up "sorta" but its dull and if i toss on my lights its gone. The clock itsself doesn't work, however the battery backup is workin cause when i hit reset it lights up but once i let go its gone again.
I dunno what todo? i was fiddlin with wires a week ago so is it possible i pulled or wrecked a wire, or is it a fuse that this runs off? From checkin the fuse box ID , i get no help so iwas wondern if someone knew a link or knew more about this ?? Any suggestions would help
Old May 17, 2005 | 12:01 AM
92b16vx's Avatar
If you were messing with the wires, go back and look to see if something is lose. Or you could remove the clock and inspect it for corrossion, or loose wires. Poosible it is just getting old. When all else fails....get a new one, they are like $5-$20 at stripyard.
Old May 17, 2005 | 05:12 PM
DamageInc73's Avatar
Default Re: Dash clock?? (EtchaSketch)
Check the 7.5 amp fuse labeled "Back up" in the fuse/relay box next to the battery. I had a similar problem after installing a stereo and found this fuse blown. I hope this is useful...
tomtomas
Honda CR-V & Element
Sep 3, 2018 04:23 PM
S33
Dec 27, 2014 10:22 AM
[Ennis_D]
Feb 8, 2013 06:40 PM
plusONE DC2
Dec 10, 2004 05:10 PM
EF4lyfe
19
Sep 27, 2004 08:43 AM
