***Gears hard to shift HELP****
Old May 16, 2005 | 06:04 PM
thegreek's Avatar
Default ***Gears hard to shift HELP****
i have a 96 ls and my gears are really hard to put in and sometimes wont even go into gear (had to hazard and turn off car and pump clutch to work). i changed my oil and the gears shift perfectly for 1 run and once turn on again the problem continues.
i then tried draining my tranny fluid and filling with new fluid and the problem still continues....
Can someone help me out a help me solve this problem
Old May 16, 2005 | 06:34 PM
KillaB18's Avatar
just had this problem. does your clutch pedal vibrate at all. can you drive push down the clutch, take it out of gear, let up clutch then push down again and then put it in gear and works fine. if you can do this then check your clutch disc. your springs can be out of wack causing it not to go into next gear. i had same problem and thats what it was. hope it helps
Old May 16, 2005 | 07:55 PM
Racermech's Avatar
Default Re: (KillaB18)
Do you have a short shifter???
If so you might want to check the bolt that runs through the shifter at the bottom, if it is too tight it can make it really hard to shift. I know, I over tightned mine when i installed it and it was really hard to shift, and that was with no load.
Old May 16, 2005 | 10:47 PM
thegreek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB18 &raquo;</TD></TR><TR><TD CLASS="quote">just had this problem. does your clutch pedal vibrate at all. can you drive push down the clutch, take it out of gear, let up clutch then push down again and then put it in gear and works fine. if you can do this then check your clutch disc. your springs can be out of wack causing it not to go into next gear. i had same problem and thats what it was. hope it helps</TD></TR></TABLE>
no i dont have a shortshifter and killa my petal does vibrate back at me a lil sometimes when i push the clutch. sometimes that works pushing it down twice. but most of the time i have to put it in neatral turn off the car and pump my clutch a few times then it will go in gear.
Old May 17, 2005 | 12:26 AM
thegreek's Avatar
Default Re: (Palmy Blue)
yah a lot of ppl saying its the clutch i might just pick up the itr clutch disk and pressure plate from the guy on ht, sounds like a good idea guys?
Old May 17, 2005 | 01:27 AM
shorto85's Avatar
Have you checked the clutch fluid level and bled it properly?
Old May 17, 2005 | 04:57 AM
Dan GSR's Avatar
Default Re: (shorto85)
if all the gears are hard to get into
then its the clutch/pressure plate
Old May 17, 2005 | 08:32 AM
Ketone's Avatar
Default Re: (OC-hbk1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OC-hbk1 &raquo;</TD></TR><TR><TD CLASS="quote">yah a lot of ppl saying its the clutch i might just pick up the itr clutch disk and pressure plate from the guy on ht, sounds like a good idea guys?</TD></TR></TABLE>
i would prefer to have a new clutch if I am going to take the time to take the transmission off, but that is my opinion. Dont forget to have the flywheel resurfaced
Old May 17, 2005 | 08:39 AM
B2FiNiTY's Avatar
Default Re: (Ketone)
Get a brand new clutch setup.
Old May 17, 2005 | 10:56 AM
thegreek's Avatar
Default Re: ***Gears hard to shift HELP**** (OC-hbk1)
yah i change the trany fluid alrday but havnt bleed it yet soo that MAY be the problem.... but NEW CLUTCH DISK and PRESSURE PLATE should fix the problem correct? anything else im leaving out?
Old May 17, 2005 | 11:05 AM
SoCo4Fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OC-hbk1 &raquo;</TD></TR><TR><TD CLASS="quote">yah i change the trany fluid alrday but havnt bleed it yet soo that MAY be the problem.... but NEW CLUTCH DISK and PRESSURE PLATE should fix the problem correct? anything else im leaving out?</TD></TR></TABLE>
not the TRANNY fluid the CLUTCH fluid. It sounds to me like you are either low on clutch fluid or there is air in the lines.
Old May 17, 2005 | 11:34 AM
thegreek's Avatar
Default Re: ***Gears hard to shift HELP**** (SoCo4Fun)
hmmm to think about it i havnt touch the clutch fluids at all maybe i should do that
Old May 17, 2005 | 12:04 PM
yrethguad's Avatar
https://honda-tech.com/zerothread?id=1245659
https://honda-tech.com/zerothread?id=1237365
https://honda-tech.com/zerothread?id=1183332
Modified by yrethguad at 4:19 PM 5/17/2005
Old May 17, 2005 | 12:42 PM
thegreek's Avatar
Default Re: ***Gears hard to shift HELP**** (yrethguad)
im guessing thats whats wrong with my clutch too that the spring came out
Old May 17, 2005 | 02:34 PM
KillaB18's Avatar
yea it sounds like a spring is either loose or came out. that should solve your problem.
Old May 17, 2005 | 04:32 PM
thegreek's Avatar
aite i just bought a itr clutch disk and pressure plate hope that solves my problem someone reassure me haha
Old May 17, 2005 | 04:48 PM
maxogsr's Avatar
Let's just hope it's either a sping of the clutch disc or a pp lip...
The worst that could be is your syncro... But it would be hard to engage only in a specific gear...
You should do like me...Take all that **** out and put a stage II clucth/pp...
Old May 17, 2005 | 05:06 PM
thegreek's Avatar
Default Re: ***Gears hard to shift HELP**** (maxogsr)
yah the guy at aamco says that the pilot bearing might of poped out
Old May 17, 2005 | 07:41 PM
yrethguad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OC-hbk1 &raquo;</TD></TR><TR><TD CLASS="quote">yah the guy at aamco says that the pilot bearing might of poped out</TD></TR></TABLE>
Doubtful. I don't think there's anywhere for it to go.
But, sure, anything can happen.
Old May 17, 2005 | 08:20 PM
Qborofinest24's Avatar
okay ive been having this same problem but i have a 92 gs so its a cable tranny but the throw out beearing makes noise when coming out of first and also when i go to shift it feels like theres somthing blocking me from getting into gear
wesk18
Jul 4, 2009 08:44 AM
YangFlavor
Transmission & Drivetrain
Apr 14, 2009 07:24 PM
D-Rob
Mar 7, 2005 12:16 PM
DA-MAX
Sep 4, 2003 05:00 AM
acuracy90
Aug 27, 2003 03:58 PM
