TPS
I have a code 7 (TPS). My throttle position sensor seems messed up. So I was wondering, what other applications, had the exact same tps as the 4th generation civic si's did. I have a the A6 throttle body, along with A6 tps, so I need a new one.
Thanks.
Thanks.
i believe all honda TPS's are the same, from 88-up. (i think, someone check me on this). any one should work, but you have to dremel a slot in the bolts holding it in, then unscrew it.
Well, the reason for me asking this was because when I got my Z6, I had a Z6 intake manifold and throttle body. But I had already maxbored my A6 throttle body, so I decided to keep the A6 tb and IM, and I had the code 7 back then, so I tried putting the Z6 tps on the a6 tb and i started the car and the idle JUMPED to 3k rpm. That is the reason for my post.
Jeeptech
May 19, 2017 08:12 PM
