fuel pump
Old May 16, 2005 | 05:13 PM
bbrian's Avatar
Default fuel pump
can some one show me where and what i need to do to change my fuel pump mine just went out today ,, thanks.
Old May 16, 2005 | 05:14 PM
bbrian's Avatar
Default Re: fuel pump (bbrian)
i know its in the back by the gas tank but what i have to do to change the thing out
Old May 16, 2005 | 05:19 PM
jlicrx's Avatar
it is in the gas tank - you need to drop the tank to get to it
Old May 16, 2005 | 05:34 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: fuel pump (jlicrx)
nope no need to drop the tank
1. remove the back seat, disconnect the wiring and push the grommet through so it falls free.
2. take off plastic cover under the car next to fuel tank, under you will find the fuel lines, disconnect, I think there are 3 of them. Also disconnect the fuel tank fill hose and vent hose. If you are having troubles with the lines, you can do most of step 3, lower the tank a bit with the jack and then work the lines.
3. brace fuel tank with jack, remove 2 bolts holding tank straps in. Should be able to drop the tank, you need to clear the exhaust in the front and on the pass side so kind of angle it out.
4. on the top of the now removed fuel tank remove round metal plate that all the lines you just disconnected went to and slowly pull out the pump, may need to turn it a bit.
91cb7h23
Feb 10, 2013 04:13 PM
Hondaisok
Sep 27, 2010 09:30 AM
enjoi_hendrix
Sep 7, 2009 07:41 AM
r3v da t3g
Oct 23, 2006 06:37 PM
alfee
Apr 14, 2005 12:40 PM
