Suspension & Brakes Theory, alignment, spring rates....
alignment ques.
Old May 16, 2005 | 04:42 PM
2khb's Avatar
Default alignment ques.
Just added coilovers to my koni's w/ 450lbs. in front and 550lbs. in the rear and a spoon rear strut bar to my '00 hatch. The rest of my set up consists of a 15/16" front sway bar and a 17mm rear bar w/ lower tie bar and a front upper strut bar. Went auto-x yesterday, 1st this season with the new springs and rear strut bar, and the car pushed way to much. Corrected some of it with changing the rebound in front, half a turn off firm and 3/4 turn off firm in rear but still had it a little. My current ailgnment is front: toe-L 1/16", R 1/32" camber-L -1.51, R -1.48 deg. caster L 1.22, R 1.23 deg. and rear: toe L and R 1/32" and camber- L -1.22 and R -1.23 deg. This is what I have ran for a couple seasons and it has hooked up pretty well but it feels much different now, any thoughts or suggestions on a ailgnment set up or anything.
Another question I have is along with pushing the rear was very skiddish and it wouold not necessarily happen when I would expect it to. i am not sure if this haas anything to do with my set up or the fact that I did a rear disk swap and I have not changed the master cylinder or proportioning valve yet. Again any thoughts.
Sorry for the long post!!!
trojan
11
Dec 13, 2010 09:23 AM
spens 91 Ef
Oct 27, 2008 02:27 PM
cre8ive
Honda Civic (2001 - 2005)
Apr 5, 2007 05:34 PM
Spartanic
Mar 24, 2004 06:13 AM
ArchAngel Sabastian
Oct 3, 2001 08:18 PM
