white spark plug on b16a
Old May 16, 2005 | 04:10 PM
komat's Avatar
Default white spark plug on b16a
after searching for a while on ht for white spark plug
i been getting mix answer that white is good or its lean
which one is it!
i have a jdm b16a sir2 the spark plug have about 500miles on it
the electrode are white
Old May 16, 2005 | 04:14 PM
Bcuz's Avatar
Default Re: white spark plug on b16a (komat)
I wouldn't worry about it, when I replace plugs I alwalys see white.
Old May 16, 2005 | 04:21 PM
EkLanta's Avatar
Default Re: white spark plug on b16a (Bcuz)
i read this some where.. it was in a repair book i found in my dad's old garage. i guess its the wear and tare of an spark plug. i dont know
Old May 19, 2005 | 05:29 PM
komat's Avatar
Default Re: white spark plug on b16a (droped_eg6)
so is white good or bad....
i have a stock jdm b16a into my 94 eg cx
im still using the cx fuel pump if that affects it
Old May 19, 2005 | 05:30 PM
Luserkid's Avatar
It all depends on how white the spark plugs are. If there whiter then paper then thats bad. But white here and there isnt a problem.
If your paranoid post a pic of your spark plugs and well tell you whats up.
Also you could check this out:
http://www.motocross.com/motop...2.htm
Old May 19, 2005 | 05:33 PM
komat's Avatar
Default Re: white spark plug on b16a (Luserkid)
i will do that this weekend
Old May 19, 2005 | 07:20 PM
95DxSi-R2
Guest
Posts: n/a
[QUOTE=komat]so is white good or bad....
white is the hotest light, blue is second hotest, the red, orange........
don't worry bout it
Old May 19, 2005 | 07:25 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: white spark plug on b16a (95DxSi-R2)
oops, lol, i didn't read the whole thing, white is fine with 500 miles. if your so worried about bieng lean do a fuel psi and volume test and look at 94 delsol specs.
Old May 19, 2005 | 07:27 PM
Deemeetree's Avatar
Electrician
There's going to be some white on it, normal signs of aging and deterioration. If they are snow white all over, something is wrong.
I believe extreme white = lean and extreme rich = black.
Old Jun 27, 2005 | 05:22 PM
komat's Avatar
Default Re: (Deemeetree)
weeee i forgot about my post on this
i just took some pics after 1500miles on them
dont mind the 3rd spark plug washer ring. i lost the new one and replaced it with a old one
Old Jun 27, 2005 | 06:31 PM
solareclipseauto's Avatar
Default Re: (komat)
you need to get rid of those autolite plugs and get some ngk's
Old Jun 27, 2005 | 06:44 PM
98b18black's Avatar
Yeah...loose the Autolite platinums....Seriously get the NGK V-Powers...1.50+ or the NGK Iridiums for like 5.00+ but the V-Powers are really good for the price...
Old Jun 27, 2005 | 08:52 PM
komat's Avatar
Default Re: white spark plug on b16a (95d15red)
whats wrong with autolite plugs?
Old Jun 27, 2005 | 09:35 PM
JohnnyWash1's Avatar
Pics look fine
No worries.
axionm1k
Jul 17, 2008 05:02 PM
USDM-EK4*
Oct 21, 2007 06:54 PM
USDM-EK4*
Oct 21, 2007 06:35 PM
92CivicSiR2
Sep 22, 2004 01:30 PM
