car over heating and idles funny
Old May 16, 2005 | 03:41 PM
CaptainDoogles's Avatar
Default car over heating and idles funny
92 honda civic 1.5
i just put a new head gasket on this weekend after having the block shaved. do day i was drive and the temp got a little hot by goin in to the white simble. i replaced the thremosta & gasket. the car also when it idles run then dies down then runs dies down like a miss or something. when the car is at a higher idle its smooth. i thought the thremosta want bad the first time but i put the new one in and it seem like its getting a litte hot. help please.
Old May 16, 2005 | 04:41 PM
bagpipe goatee's Avatar
it could be a bubble in your coolant system, did you use the bleeder to get them out?
the bubbles tend to hang in the idle air control valve and the other idle valve (the one that's meant for warming up the car) and my car will get hot if theres a bubble in the coolant.
Old May 16, 2005 | 04:51 PM
Big Bang's Avatar
Default Re: car over heating and idles funny (CaptainDoogles)
did you torque everything down in the right order and everything? Sounds like a bad head gasket still.
Old May 17, 2005 | 02:27 AM
Default Re: car over heating and idles funny (The Converted)
yes i torque it all in the right order. i had this issue before. the original problem was it over heated and the colent over flowed the resiwar. the was little coolent in te engine. if your saying that there could be air in a control value maybe i should check the gaskets. theres no coolent leak thought.
Old May 17, 2005 | 03:55 AM
yeaa, today i was checking the anti freeze and i noticed that the number 3 injector is leaking. im asumming that is the problem with the missng. put new o-rings on all the injectors. could that be how air is getting into the coolant to?
Old May 17, 2005 | 04:23 PM
Big Bang's Avatar
if you ran it for a while with a bad head gasket it could have eroded the metal where it was leaking. Unfortunatly that means a full tear down if that was the case
EM2 Charlay
Honda Civic (2001 - 2005)
Sep 3, 2013 05:32 PM
cs451
Oct 9, 2010 07:32 PM
blue89hatch
Aug 13, 2008 05:09 AM
Since 1983
19
Apr 20, 2008 12:25 AM
