power steering removal...HP gain?
Old May 16, 2005 | 03:26 PM
sickofitall1113's Avatar
Default power steering removal...HP gain?
is there any gain to removing your power steering pulley and assembly in any way?
Old May 16, 2005 | 03:35 PM
Racermech's Avatar
Default Re: power steering removal...HP gain? (sickofitall1113)
Straight up gain....no
Free up HP yes.
The engine makes the same HP with or without PS. With the removal of PS it frees up a couple of HP, meaning the engine does not have to use any power to turn another belt, less drag=more power.
There was a dyno around at one point that had a before and after run. Before with AC and PS, after was no AC no PS and the N1 crank pulley, there was a 5-7hp "gain"
The actually pump and unit only weighs 20lbs(maybe) it takes aprox 100lbs to gain 1/10sec on the 1/4mile.
Old May 16, 2005 | 03:45 PM
Default Re: power steering removal...HP gain? (Racermech)
awesome explaination thanks dude. i actually already did it today and i saw a little bit but nothing that drastic. does it matter if i didn;t take out the lines that carry the fluid? cuz i didn't feel like taking the bumper off today.
Old May 16, 2005 | 05:59 PM
RedGSR's Avatar
I hope you didn't just remove the p/s belt. Your steering rack is going to go bye bye in a few days
Old May 16, 2005 | 06:59 PM
Default Re: (RedGSR)
no no no no i may be new here but im not a moron haha. i took out the whole assembly with the pulley and the belt with it, the resevoir...all the hardware peices, just not the PS fluid lines that run through ther bumper and into the cabin through the firewall. i might just put the whole thing back on anyway it doesn't even seem worth it. any opinions?
Old May 16, 2005 | 07:26 PM
Racermech's Avatar
Default Re: (sickofitall1113)
There should be no PS lines going into the cabin.
You should have 2 lines going to the front of the radiator and back to the fluid tank. you will have one large line going from the pump down the the rack, and one line from the rack back to the tank.
Do a search for PS removal kit by a guy names pandawn(sp?) He sells a kit with all the fittings hoses and all. lets the fluid still circtulate, It is supposed to be easier than just taking the belt off, but not as easy as having full PS. I installed it on my car, but have not driven it yet.
Old May 16, 2005 | 07:31 PM
94whtgsr's Avatar
do you have any support of ur claim of ur steering rack going bye bye, no???
Old May 16, 2005 | 07:46 PM
Racermech's Avatar
Default Re: (94whtgsr)
Well without the belt the fluid just stays in one spot. It will lead to extra wear.....down the road. In a few days is a little excessive.
Do a search about it, the subject has been covered many times. With the pandawn kit is allows the fluid to move the way the system is designed too. I did a lot of reasearch about just takng the belt off compared to buying the kit, and i went for the kit.
Old May 16, 2005 | 08:08 PM
Default Re: (Racermech)
ok well hold on for a second. i didn;t just take the belt off, thats ridiculous. i took the whole thing out. except the lines themselves which i plugged up where it would attach to the resevoir and to the peice itself. so its basically flowing into nothing. its hitting the stoppers i put in and going right back where it came from i assume. like i said, it didn;t do much at all and im prob gonna put it back on. some kid said that if you take it off it adds 25 hp but maybe thats on a the 91 motor he has or MAYBE hes full of crap haha. i dunno. but i def didnt get 25 i know that.
PS. and after i took the thing out i had my friend turn the wheel back and forth and got all i could to spurt out into a container. so whatever was in there is gone. if theres any fluid left in it...its not much of anything at all.
Old May 16, 2005 | 09:32 PM
Nightrider_si's Avatar
k what you need to do is read padiwans post and the links in it... it will explain to you that the ideal setup is to run both the lines from the rack into a breather \ reservoir so that when you turn your wheel ur not fighting the fluid in the rack.. not only does it make ur steering easier to turn but it also extends the life of ur rack...
Old May 16, 2005 | 10:04 PM
G2integra217's Avatar
Arnt most integras "speed sensitive, Power assisted" Which means it has a basic rack n pinion just a lil extra boost at stand still for easier turning and parking capability. I had my my power steering pump out for about 2 months now with nothing special done.. its just rack n pinion when you take out the pump and resevior. At least in my 91 Rs it is.
Old May 17, 2005 | 03:41 AM
m R g S r's Avatar
Default Re: (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">I still dont have any idea why somone would take out the PS in there car. Unless you race while going around a corner It doesnt make any difference. The power steering pump rotates freely I dont see how it robs HP.</TD></TR></TABLE>
I did mine because of a fluidamper race pulley. No room for the PS belt. I still have the power steering rack, no manual steering rack. It's a bitch to turn in parkking lots, but I like the way it feels on the roads, much tighter, no where near as loose as my other integras.
Old May 17, 2005 | 04:55 AM
Milanogisser's Avatar
Default Re: (m R g S r)
I hate it as well(removed that is).Not that you really have a choice with a custom(homemade) turbo kit.As stated above its great when turning but in tight spaces be ready to use both hands!
Old May 17, 2005 | 05:19 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
i doubt the steering rack will go to **** in a few days; when i was 16 and had my first car(88 accord), a rock got lodged in my ps pulley, and obviously the belt fell off. i felt a noticeable gain in low/mid range acceleration, and since i was lazy i let it go for over a month...until school started and i had to parallel park everyday lol. so after a month i put a belt back on and it worked perfectly fine.
Old May 17, 2005 | 05:40 AM
kingteghelm's Avatar
I don't think taking out ur PS is really worth like 2 hp, i hate driving cars without it
Old May 17, 2005 | 06:46 AM
Tweakmeister's Avatar
Default Re: (kingteghelm)
I gotta post my PS removal article on the site again...
search archives...good gains. been running without for a couple years now.
Old May 17, 2005 | 06:39 PM
Racermech's Avatar
Default Re: (Tweakmeister)
https://honda-tech.com/zerothread?id=563116
Ok here is the kit I was talking about. So you are running the rack dry?? With no PS fluid??
Old May 17, 2005 | 07:07 PM
haha uhhh i guess i am running it dry. im sure theres still some in there but its plugged on both sides...im taking from your question that it would be bad to run the steering dry...even WITHOUT the POWER steering fluid and the power steering peice out. if you dont have the power steering assembly in it why would you need the fluid? please excuse my ignorance on this subject.
Old May 17, 2005 | 07:33 PM
Racermech's Avatar
the fluid is there to keep everything lubricated......kinda like oil in your engine
Rear through the link i posted above. That is the kit I have. There is tons of great info in that thread
Old May 17, 2005 | 07:45 PM
ok thanks i will. but until then, tomorrow morning im gonna put the thing back in so i dont **** anything else up. i will get that kit though. thanks a lot
Old May 17, 2005 | 08:02 PM
m R g S r's Avatar
ive been running mine dry for a year now...still works perfectly. just pulled everything off. thats it.
Johnoolo
Dec 29, 2018 03:11 PM
BigECivic
Apr 13, 2006 12:27 PM
92bubblesi
Sep 15, 2004 08:32 AM
Comtechgsr2000s
Dec 2, 2001 05:52 PM
ActiveAero
Oct 15, 2001 11:49 AM
