lowered R... do u still use factory alignment specs ?
my R is lowered with 2.5 Neuspeed springs with koni 5 way adj. yellow shocks set all the way up... and I was told by a Honda tech that you can't use the factory settings to align a lowered car... He also said if I align the car wth the Ingalls camber kit that I am using in the front (which mounts to the ends of the A arm) to the factory specs it would damage the car, such as rubbing the fender walls and eventually hit the top where the shock mounts in.... Please help with any suggestions and any alignment specs you guys run.... Are any of u guys using the ingalls kit ? Where do u get your alignments done ? thanks
virginia_dude
Feb 25, 2004 08:54 AM
