koni yellow install
Old May 16, 2005 | 08:43 AM
upsfutch's Avatar
Default koni yellow install
took my lude to a mechanic to install my koni yellows and springs today. I bought them off someone online a while back. Anyways they say the dont fit, but when I look up one of the struts number on it 8041 1155, it says they are for my 2000 prelude. Am I missing something to install these.
They said the hole was two small on the lude for these. I dont know anything about this kind of sruff (yet). Are there some kind of mounts I need or did I get the shaft? Any input would be awsome. Thanks
Old May 16, 2005 | 11:40 AM
upsfutch's Avatar
Default Re: koni yellow install (upsfutch)
bump for a sucker who needs some input
Old May 16, 2005 | 11:52 AM
lakerschamp2000's Avatar
do it yourself
Old May 16, 2005 | 12:01 PM
syntax.'s Avatar
mechanics like to make a markup on parts and who can blame them. If you are confident you have the right parts then either take it to another shop or find a friend whos done it before. Its not a hard job, but its not one that you should dive into flying blind either.
Old May 16, 2005 | 12:23 PM
upsfutch's Avatar
Default Re: koni yellow install (syntax420)
Well I called Koni and they said that there strut is a little bigger so you have to drill where the srtut comes through the emgine bay. Iguess its a 10mm and you have to go to a 12mm.
Most places I called said they wouldnt even do this because it could f up what ever they are drilling.
But I know it has been done so is there anyone who has screwed up and is it fixable, or do I put my lude in the hands of someone who could shaft my ride?
Doining it myself isnt really an option, no tools and I have to put the springs on and dont know anyone who has a compressior.
for being a pain in my ***
Old May 16, 2005 | 01:40 PM
tdo's Avatar
tdo
i did this when i was 16.
i just dove right in. gotta learn sometimes.
Old May 16, 2005 | 01:59 PM
mafia's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">i did this when i was 16.
i just dove right in. gotta learn sometimes.</TD></TR></TABLE> i agree, you need 12, 10, and 14mm. i think. thats not to spendy, but compressing them shouldent be that hard if you got some one heave to help you... (ive made my brother help me) so its posible :D hope u get them in
Old May 16, 2005 | 03:45 PM
Default Re: koni yellow install (mafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafia &raquo;</TD></TR><TR><TD CLASS="quote"> i agree, you need 12, 10, and 14mm. i think. thats not to spendy, but compressing them shouldent be that hard if you got some one heave to help you... (ive made my brother help me) so its posible :D hope u get them in</TD></TR></TABLE>
you also need 17mm. if you are lazy and not having tools, drive stock.
Old May 16, 2005 | 05:51 PM
upsfutch's Avatar
Default Re: koni yellow install (lakerschamp2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">
you also need 17mm. if you are lazy and not having tools, drive stock. </TD></TR></TABLE>
That isnt very nice. First what the **** does lazy have to do with anything? If you dont have anything positive or helpfull to say you should post. You guys that post BS just to get your posts up are a joke.
I like my lude just as much as the next person but when you are getting started you wont have the tools or the know how.
But I guess you were born with the knowledge and the skills.
Old May 16, 2005 | 06:49 PM
limpmode's Avatar
just fyi, the tools required are not that expensive in case you want to give it a run. those plus a helms manual would cost less than labor at a shop. a friend and a case of beer and you're set. yeehaaa
tdo's Avatar
tdo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by upsfutch &raquo;</TD></TR><TR><TD CLASS="quote">
But I guess you were born with the knowledge and the skills. </TD></TR></TABLE>
tools dont cost much. most bolts on hondas are 10mm, 12mm, 14mm, 17mm, and 19mm. just get those for now. its like couple dollars for each one. then go get a ratchet.
its not that hard to do.
Old May 16, 2005 | 06:57 PM
tdo's Avatar
tdo
Default Re: koni yellow install (tdo)
heres a Craftsman Mechcanics tool set and its pretty cheap.
http://www.sears.com/sr/javasr...82000
if you have money to buy koni yellows then you have enough money to get a nice tool set. put out like 200-300 for a nice tool set. i got a 264pc set for $200.
why pay a shop the labor money when you can use that for other parts and tools.
btw a jack and jack stand is prolly like $120 or even cheaper.
good luck.
EDIT - heres another one thats even better for $90
http://cgi.ebay.com/ws/eBayISA...sting
one more thing. dont get cheap tools because they will break. i broke a couple no name sockets many times.
Old May 16, 2005 | 09:21 PM
bad-monkey's Avatar
i'm so confused about this drilling business. i didn't drill **** when i installed my konis, and can't figure out why you'd have to?
Old May 16, 2005 | 09:28 PM
i knew many guys who are like this, "why would i work on my car when i can afford someone do it for me?"
Dude, have you ever seen a girl works on her car before?
anyhow, it's your car and your $$$, do whatever you want.
Old May 17, 2005 | 12:36 AM
SoOHiGH's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i'm so confused about this drilling business. i didn't drill **** when i installed my konis, and can't figure out why you'd have to?
thats what i was thinking. i installed koni yellows with some eibach and you dont have to drill anytihng.
maybe that shop is trying to make you pay for more?
Old May 17, 2005 | 12:55 AM
@ries's Avatar
Default Re: (SoOHiGH)
maybe they're talking about drilling out the holes in the stock dust boots. since the koni shaft is bigger than stock.
Old May 17, 2005 | 04:43 AM
upsfutch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoOHiGH &raquo;</TD></TR><TR><TD CLASS="quote">
maybe that shop is trying to make you pay for more?</TD></TR></TABLE>
bingo. This shop that I took it to quoted me a price of 120 for all the springs and struts install and they would do an alignment.
Well when I get there they tried to renig saying that they ment for the front only.
I told them why would I only drop the front. so they were like yeah will do it.
Then they called saying they were the wrong struts and they must be for an accord
Anyways Im new to cars dont really have any friends who are into it. most of them arent into this kinda stuff. As for tools I have sum tools like rachets and stuff but I dont have anything to compress the spring and felt for 120 bucks it was worth it to have someone else do it for me. But now starting to see that it is better to do myself. I need to find me some new friends with preludes
I didnt understand this drilling crap either because I searched and didnt see anything on this. I could use help if someone is from Jville FL. and has done this, I really dont want to drill anything that would cause me to never be able to go back to stock. I do apprtiate all the advice and those of you who do everything yourselves I definetly respect
Old May 17, 2005 | 06:26 AM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: (upsfutch)
if your goin to pay someone find a different shop they sound like they wanna rip you off
Old May 17, 2005 | 07:42 AM
bad-monkey's Avatar
Default Re: (@ries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries &raquo;</TD></TR><TR><TD CLASS="quote">maybe they're talking about drilling out the holes in the stock dust boots. since the koni shaft is bigger than stock.
ah, the dustboots were kind of a bitch, but that's because i have the tiniest hacksaw in the world. ain't nothing a dremel and some cutting wheels can't handle, or a bandsaw...should take the shop 1 min per boot.
Old May 17, 2005 | 07:54 AM
foshizllmynizl's Avatar
Is there a koni install write up for BB6? The one for the ARRR seems to be very helpfull, how well does it compare to our install?
Old May 17, 2005 | 11:31 PM
@ries's Avatar
true that. i think i used a uni-bit when i put mine in.
Old May 17, 2005 | 11:41 PM
tdo's Avatar
tdo
Default Re: (@ries)
now that sounds right. drilling the dust covers isnt too hard. when i did mines i used a dremel and it was easy.
the only hard part about installing the koni's was getting that bolt on the bottom back in .
mg23
Suspension & Brakes
Apr 6, 2008 06:42 PM
.I.Need.Money.
Suspension & Brakes
Feb 9, 2007 01:44 PM
Daniel_san
Sep 1, 2004 06:57 AM
yangrou8
Jul 29, 2003 09:05 AM
DevinW
May 7, 2002 05:27 PM
