how do i read my oil pressure gauge?..what to look for?
Old May 16, 2005 | 06:44 AM
IneedBoostInTheCoupe's Avatar
Default how do i read my oil pressure gauge?..what to look for?
just got it installed and not sure how to read it. I put it in cause my piston rings just started to go bad and my car is my daily driver. If i'm driving on the highway i want to know when i've lost too much oil and i need to pull over and pour some in. Where is it supposed to be at what rpm? my idle jumps around a little bit but nothing crazy. When i idle at 800-900 it stays at about 16 psi....when it idles at 400-500 it goes as low as 11-12 psi but never lower then that. last night when i idled at about 800-900 it stayed at 20-21 psi....but then eventually dropped back down to what i stated before. Is there anything i should look for to know whether or not i should be worried?
BTW: motor is a d16z6
Old May 16, 2005 | 06:51 AM
Deemeetree's Avatar
Electrician
How about you do it the right way and rebuild/replace your piston rings?
Old May 16, 2005 | 07:32 AM
Default Re: (Dimitri_EG8)
how about answering the question my man......if my pockets could afford that then that is what would be done...but until then easy driving and keeping tabs on my oil.
Anybody else that can ANSWER my question and not give their opinion?
Old May 16, 2005 | 07:44 AM
AutoXer's Avatar
Default Re: (B20vtecNJcoupe)
The pressure gauge isn't an oil level gauge. Of course when you run out of oil, or you starve the pump, you will have no pressure, but it's not designed to be used that way.
I'd be suprised if you got any meaningful answers on this topic, because I'm not sure if anyone has used one to know when to put in oil. Why don't you just check the dipstic every hundred miles or so? I mean, I know it's a pain and all, but at least you'll know for sure.
Old May 16, 2005 | 07:52 AM
CRXified's Avatar
Default Re: (AutoXer)
i cant see how checking ur oil is a "pain" IMO
Old May 16, 2005 | 08:26 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtecNJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">how about answering the question my man......if my pockets could afford that then that is what would be done...but until then easy driving and keeping tabs on my oil.
Anybody else that can ANSWER my question and not give their opinion?</TD></TR></TABLE>
your pressure will remain the same till your oil level goes dangerously low. its not a level gauge its a pressure gauge. you wasted money on the gauge. by the time your oil goes low enough to cause a pressure fluctuation you a) will already damage your engine more, b) have your light turn on
Old May 16, 2005 | 06:44 PM
Default Re: (CRXified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">i cant see how checking ur oil is a "pain" IMO </TD></TR></TABLE>
Did i say i don't check my oil?.....Did say that was a pain? Stop assuming ****. I check my oil everyday. But i am planning a road trip this weekend....i'll be doing 3 hours on the NY thruway. Checking my oil before i leave isn't gonna help me 2 hours into the trip at 75-80 mph. And i could pull over during the trip, but then i have to sit and wait 15 min. for all the oil to come down to get an accurate reading. But seeing how people answered my question like i asked, now i know it isn' t gonna help me. Now i have to pull over and do this anyway and delay my trip even longer.
Old May 17, 2005 | 09:02 AM
CRXified's Avatar
Did i say i don't check my oil?.....Did say that was a pain? Stop assuming ****. I check my oil everyday. But i am planning a road trip this weekend....i'll be doing 3 hours on the NY thruway. Checking my oil before i leave isn't gonna help me 2 hours into the trip at 75-80 mph. And i could pull over during the trip, but then i have to sit and wait 15 min. for all the oil to come down to get an accurate reading. But seeing how people answered my question like i asked, now i know it isn' t gonna help me. Now i have to pull over and do this anyway and delay my trip even longer.</TD></TR></TABLE>
this wasnt in reference to ur post, if u read all the replys, u would have read this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
no get off the computer and check ur oil fool
Old May 17, 2005 | 09:07 AM
ogabudiah's Avatar
really how much is this thing burning?
like a quart a day?
Old May 17, 2005 | 09:11 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: how do i read my oil pressure gauge?..what to look for? (B20vtecNJcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtecNJcoupe &raquo;</TD></TR><TR><TD CLASS="quote">Where is it supposed to be at what rpm? </TD></TR></TABLE>
my car (b series) is 25~40 psi at idle, and 70~80 psi under wot/vtec.
Old May 17, 2005 | 09:29 AM
Ricey McRicerton's Avatar
Default Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
your pressure will remain the same till your oil level goes dangerously low. its not a level gauge its a pressure gauge. you wasted money on the gauge. by the time your oil goes low enough to cause a pressure fluctuation you a) will already damage your engine more, b) have your light turn on</TD></TR></TABLE>
I agree that it's not going to solve his checking problems, but it will alert him before he gets to the point of an idiot light. I've heard they turn on about 3 psi. I managed to snap my sensor almost completely in half changing my oil, and drove around for 2 days before the sensor finally turned the idiot light on.
Your pressure is going to be high when you first start the car until it warms up.
Default Re: (ogabudiah)
this wasnt in reference to ur post, if u read all the replys, u would have read this </TD></TR></TABLE>
My fault, just frustrated about the wasted money i spent on the gauge. INstead my comment was directed towards dood who said it was a "pain".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogabudiah &raquo;</TD></TR><TR><TD CLASS="quote">really how much is this thing burning?
like a quart a day?
not much...only had to add half a quart in the last week and a half...and this includes only letting vtec kick in maybe twice in this time span. It doesn't leak and it only smokes lightly when vtec kicks in. Just trying to avoid to what happened to me 2 weeks ago and let my car last me a couple more weeks till i get my swap.
Here is what happened two weeks ago that started all this:
https://honda-tech.com/zerothread?id=1240115
Old May 17, 2005 | 09:33 AM
TurboTagTeam's Avatar
Default Re: (Ricey McRicerton)
An oil pressure gauge will tell you nothing about your oil level. The pressure is gonna stay normal untill your oil level drops below the oil pick-up. Then your fucked!!
Old May 17, 2005 | 09:41 AM
Marauder's Avatar
Default Re: (TurboTagTeam)
Once my engine is warm, I get 12 psi of oil pressure at idle.
normal oil pressure while cruising is around 50psi
oil pressure with foot heavy on the gas pegal 70-75 psi
When the engine is cold, oil pressure goes close to 90 psi.
EG6 Love
Mar 23, 2010 04:16 PM
dragvixen
Jul 10, 2009 11:20 AM
1990_integra_DA9
May 4, 2009 03:03 PM
booscivic
Feb 5, 2004 06:34 PM
