Tow hooks + rusted bolts = WTF???
Old May 16, 2005 | 05:21 AM
_Cyclone_'s Avatar
Default Tow hooks + rusted bolts = WTF???
I just figured out that I need to remove the driver side OEM tow hook for some FMIC piping. Problem is... the bolt heads are rusted beyond recognition. Any suggestions?
Old May 16, 2005 | 06:19 AM
Deemeetree's Avatar
Electrician
What do you do when something is rusted and doesn't budge, especially something that doesn't get placed into use for God knows how long?
Old May 16, 2005 | 06:31 AM
JwM's Avatar
JwM
Default Re: (Dimitri_EG8)
PB Blaster + impact wrench = teh win.
Old May 16, 2005 | 07:22 AM
TheNasty0ne's Avatar
Default Re: (JwM)
Lube it up and use some muscle
Old May 16, 2005 | 07:49 AM
Farmer Brown's Avatar
Default Re: (JwM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JwM &raquo;</TD></TR><TR><TD CLASS="quote">PB Blaster + impact wrench = teh win.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoBryan &raquo;</TD></TR><TR><TD CLASS="quote">Lube it up and use some muscle</TD></TR></TABLE>
Are you talking about bolts here...or................?
Old May 16, 2005 | 07:58 AM
Eddiebx's Avatar
if the bolt heads are that fucked up jsut get a set of big vise grips and have at it
Old May 16, 2005 | 08:10 AM
Paperchaser's Avatar
Default Re: Tow hooks + rusted bolts = WTF??? (CycloneBlue_1.6EL)
All of the above
Old May 16, 2005 | 08:13 AM
jolt-tsp's Avatar
Default Re: Tow hooks + rusted bolts = WTF??? (Paperchaser)
Worst case scenario, get out the drill
Old May 16, 2005 | 12:53 PM
_Cyclone_'s Avatar
Default Re: (RyanE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanE &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking about bolts here...or................?</TD></TR></TABLE>
The bolt heads are rusted beyond recognition... Vice grips won't work due to the size of the bolts. When I try and put a socket on them, they just crumple apart more. I think I'm gonna try the cutting wheel...
Old May 16, 2005 | 12:55 PM
Black_SiR's Avatar
Dremel is your friend
Old May 16, 2005 | 01:15 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Black_SiR)
Take a drill bit slightly smaller than the diameter of the threaded section of the bolt, and drill down through the center of the head of the bolt, dont worry about going through the threaded section. Now put a chisel up to the side of the bolt head, and hit it with a hammer, if you get the chisel under the edge of it somehow, should pop right off, if not, a few whacks will bend then break the head off.
Prudz_lude
Feb 23, 2008 10:06 PM
D16SohcVtec
Feb 16, 2008 02:00 PM
LandPirateDA
Jun 19, 2007 10:12 PM
motorhead_ls
Jun 23, 2006 03:28 PM
Blazin Civic
11
Jun 20, 2005 03:15 PM
