frends vtec not kicking in?
Old May 15, 2005 | 10:29 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default frends vtec not kicking in?
now i know this is a EG question but before i get flamed for it, this is not my car and am just curious.
my friend has a 94 civic EX with a D16Z6 and P72 ECU
all u guys say "u can 'feel' VTEC kick in and 'feel' the car pull harder" well that doesent happen. i mean absolutily no change. i hooked a scantool up to it and it says it's operating at 4200 RPM. is that correct for a P72?
what could cause this? he has plenty of oil presure. infact we shorted the spool solonoid to +12 and the car ran like ****. like not getting enough fuel.
Old May 15, 2005 | 11:14 PM
njn63's Avatar
sohc vtec doesn't have a big kick. A lot of people claim it's hardly noticable.
Old May 16, 2005 | 05:20 AM
Boosted Power's Avatar
Sohc vtec will not kick in as strong as the dohc vtec. There should be a difference when vtec does crossover though. Should be a difference in power and noise.
Check the Vtec solenoid. See if that's still good. Also check wiring.
Old May 16, 2005 | 08:29 AM
DieMaster's Avatar
Default Re: (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">sohc vtec doesn't have a big kick. A lot of people claim it's hardly noticable.</TD></TR></TABLE>
i'm glad u told me that b4 i got a sohc swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Power &raquo;</TD></TR><TR><TD CLASS="quote">There should be a difference when vtec does crossover though.</TD></TR></TABLE>
and when is that? 4200 right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Power &raquo;</TD></TR><TR><TD CLASS="quote"> Should be a difference in power and noise.</TD></TR></TABLE>
theres abolutly none at all. no change. it dosent even pull harder. how is it supost to sound? deeper?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Power &raquo;</TD></TR><TR><TD CLASS="quote">Check the Vtec solenoid. See if that's still good. Also check wiring. </TD></TR></TABLE>
we did. hooked it up to +12 and it ran like ****. besides if there was a wiring problem we would get a CEL witch were not.
Old May 16, 2005 | 08:57 AM
SiR Inspired ED7's Avatar
Default Re: (DieMaster)
on my friends sohc vtec we can't hear vtec and his motor's healthy... my vtec sounds...vrooommmmm Vtec :bhhua, but i have a b16 so sounds diff then a single cam atleast IMO
Old May 16, 2005 | 10:11 AM
crx-treme's Avatar
Default Re: (88 Crx Si)
yeah my friends sohc vtec doesnt sound too lous when vtec engages....hardly tell. but yeah b16 sounds so sweet when vtec kicks in....pulls hard too
Old May 16, 2005 | 10:14 AM
Bjorn20's Avatar
Default Re: (crx-treme)
hehe, sounds good for me since im looking forward to a b16 in a couple months
Old May 16, 2005 | 10:23 AM
kid-crx's Avatar
vtec equals eeeeeeeeeeeeeeeeeeeeeBAAAAAAAAA
Old May 16, 2005 | 11:09 AM
Bserieskllr's Avatar
sohc you cant really hear it, but if you disconnected the vtec you can tell that its not pulling as hard to the redline.
Old May 16, 2005 | 12:55 PM
Mach69's Avatar
Default Re: frends vtec not kicking in? (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">my friend has a 94 civic EX with a D16Z6 and P72 ECU</TD></TR></TABLE>
You do know that the Z6 is suppose to be running a P28 ecu. The P72 ecu is for the GSR motor (B18C1), not the D16Z6. The p72 is designed to run dohc engines. If it is running the z6 and it is not chipped, there is your problem. If the p72 is chipped and designed to run the Z6 then here is a link you need:
https://honda-tech.com/zerothread?id=830163
Old May 16, 2005 | 02:00 PM
DieMaster's Avatar
Default Re: frends vtec not kicking in? (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">
You do know that the Z6 is suppose to be running a P28 ecu. The P72 ecu is for the GSR motor (B18C1), not the D16Z6. </TD></TR></TABLE>
ur right it's a P28 ECU. it's totaly bone stock. i was thinking of P72 when i wrote that
so is 4200 correct for a P28?
Old May 16, 2005 | 02:53 PM
i think stock engagement for p28 is 4800
Old May 16, 2005 | 03:23 PM
slowman's Avatar
I took way too long
Default Re: (Bserieskllr)
Yeah SOHC VTEC sounds/feels nothing like DOHC VTEC
Old May 16, 2005 | 05:07 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">so is 4200 correct for a P28?</TD></TR></TABLE>
No, but 4800 is, and depending on other factors, like throttle percentage, oil pressure, etc. It can be as high as 5200 rpm.
Make sure you aren't throwing codes and check the thread I have in my other post.
cmfnelson
Oct 12, 2012 01:20 PM
obuhmyuh
30
Dec 21, 2007 12:10 PM
exclusive_vtec
May 18, 2004 12:57 PM
GreenEX
Feb 19, 2004 06:59 PM
blackccoupe
81
Nov 20, 2003 02:07 PM
