Piston Ring End Gap Questions
Old May 15, 2005 | 10:25 PM
THEUSED's Avatar
Default Piston Ring End Gap Questions
Im checking my piston ring end gaps and they are all within spec, but I was wondering if there is a certain number Im looking to get, kinda like when you want to run certain clearences with your bearings?
Old May 16, 2005 | 02:21 PM
THEUSED's Avatar
Anyone?
Old May 16, 2005 | 08:21 PM
onefasazn's Avatar
you'll wanna look for 1/1000 per inch of bore...Any more help needed, go ahead and PM me
Old May 16, 2005 | 08:22 PM
onefasazn's Avatar
oh yeah...also depends on what pistons being used as well
Old May 17, 2005 | 08:47 AM
atcrx's Avatar
Default Re: (onefasazn)
also depends on type of motor too. NA or nitrous or Forced induction.
Old May 18, 2005 | 02:07 PM
THEUSED's Avatar
GSR Block, 81mm Bore, JDM ITR Pistons, All Motor Daily Driver
Old May 19, 2005 | 02:39 AM
THEUSED's Avatar
Im trying to assemble my motor here, if they are in spec is it all good to go?
Old May 19, 2005 | 08:36 AM
atcrx's Avatar
Default Re: (THEUSED)
Yes. Usually the only time I worry about end gap on a new assemble is if it is sprayed or turbo'ed. All motor doesn't create the heat or pressure that a nitrous motor does.
Old May 19, 2005 | 01:35 PM
THEUSED's Avatar
Alright thanks alot atcrx you're a life saver
iwannarace
15
Oct 31, 2013 06:25 PM
TheoneTheycallVille
Oct 20, 2009 06:01 PM
kdawgy2k1
32
Jan 28, 2009 03:18 AM
KURUPTinc
Aug 25, 2007 12:24 PM
Thats-so-Ls
Dec 29, 2001 07:17 AM
