no spark...no fuel....wtf!?!? help me out fellas
Old May 15, 2005 | 05:55 PM
sykotik sol's Avatar
Default no spark...no fuel....wtf!?!? help me out fellas
ok, im cruisin down the highway at about 80 and engine just dies...no noises, smoke, nothing..pull over and cut it off, get out everything looks to be ok, nothing visually the matter. i tried to start, turns over just wouldnt start, towed it home and began the search for probs....
no blown fuses, main relay works fine, however fuel pump doesn't prime(usually you can hear it), and theres also no spark and no fuel on gauge on fuel filter(also cracked fuel line to rail and turned over.nota) i thought coil or somethign went bad, changed out entire dizy with friends working dizy, and still nothing..i ran a wire straight from battery to fuel pump harness and it made it prime and fuel press went up on gauge....anybody take a wild guess at wtf else it could be?
Old May 15, 2005 | 06:19 PM
Lord Helmet's Avatar
Default Re: no spark...no fuel....wtf!?!? help me out fellas (sykotik sol)
engine type?, mods?, blah blah blah......
Old May 15, 2005 | 06:26 PM
Default Re: no spark...no fuel....wtf!?!? help me out fellas (Lord Helmet)
ls block
itr head
gt35 turbo-15psi
walbro 255
600cc inj
hondata s200
3bar map
Old May 15, 2005 | 06:35 PM
checked the PGM-FI main relay yet? the part under the driver's side compartment.
also any codes?
Old May 15, 2005 | 06:42 PM
check the fuel pump ground going fromm the pgm-fi relay harness to the fuel pump for continuity. could be a short or break in the wire. somewhere.
Old May 15, 2005 | 08:47 PM
1slowhatchie's Avatar
how did you check your main relay to make sure it was workin fine, did you put a diff. main relay in?I still think it is your main relay goin bad try changing it out with a diffrent one if you haven't did so.
Old May 16, 2005 | 05:36 AM
Default Re: no spark...no fuel....wtf!?!? help me out fellas (1slowhatchie)
the main relay i checked is behind glovebox, and yes i changed it out w/ a good one out of a friends car...my car is a 96' so would there still be a relay under driverside of dash? or only the one behind glovebox?
Old May 16, 2005 | 03:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotik sol &raquo;</TD></TR><TR><TD CLASS="quote">the main relay i checked is behind glovebox, and yes i changed it out w/ a good one out of a friends car...my car is a 96' so would there still be a relay under driverside of dash? or only the one behind glovebox? </TD></TR></TABLE>
96' WHAT? accord?, civic?, integra? you still haven't mention what car you have other then the engine specs.
Old May 16, 2005 | 03:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowhatchie &raquo;</TD></TR><TR><TD CLASS="quote">how did you check your main relay to make sure it was workin fine, did you put a diff. main relay in?I still think it is your main relay goin bad try changing it out with a diffrent one if you haven't did so.</TD></TR></TABLE>
Get yourself a Helms manual I don't know why people work on a car without one in the first place. It's like working blind on engine.
BTW like I said earlier: CHECK ALL WIRES GOING FROM PGM-FI MAIN RELAY GOING TO THE FUEL PUMP for continuity, breaks or damages.
Old May 16, 2005 | 03:49 PM
sorry charlie, 96' civic dx
Old May 16, 2005 | 03:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotik sol &raquo;</TD></TR><TR><TD CLASS="quote">sorry charlie, 96' civic dx</TD></TR></TABLE>
you checked the wiring like I said?
Old May 16, 2005 | 05:45 PM
i believe you checked the wrong relay, the main relay should be on the driverside under the dash and above your fuse box
Old May 16, 2005 | 06:24 PM
i havent checked wiring yet, but my main relay assembly is behind glove box(even says main assbly relay) on it....however ive heard theres one under drivers side...but is that only for obd1 cars? or obd2 also??
Old May 17, 2005 | 09:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotik sol &raquo;</TD></TR><TR><TD CLASS="quote">i havent checked wiring yet, but my main relay assembly is behind glove box(even says main assbly relay) on it....however ive heard theres one under drivers side...but is that only for obd1 cars? or obd2 also??</TD></TR></TABLE>
Do you even have a tech manual aka Helms manual to use? It's stupid to work on a car without one in the first place. If you have it, it will show you exactlly the proper trouble shoot techniques to find the reason the fuel pump is working only if you hard wire it to the battery. Work smarter not harder.
civic28
Mar 26, 2014 04:18 PM
MikesArmy
10
May 1, 2006 11:44 AM
crazygerman
Mar 4, 2006 11:57 AM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
CRXMATT
Mar 20, 2003 06:01 PM
