Car wont go into gear when on...replaced the clutch
Old May 15, 2005 | 04:37 PM
KekahaB18's Avatar
Default Car wont go into gear when on...replaced the clutch
so i just replaced my clutch to day and found that one ofsprings on the inner part of the clutch had broken off parcially. I heve never seen that before. so the new clutch is in and all the gears work except reverse. i took the linkage off and tryed to put it into reverse manually. it just wont go in. what is that? could it be something bent? geez im really tired of taking apart the trans. thanks for any advise you could offer me.
Old May 15, 2005 | 05:43 PM
SPOON_FED_DC_2's Avatar
Default Re: Car wont go into gear when on...replaced the clutch (KekahaB18)
I had the same problem with my gsr changed the clutch and about 1 or 2 months later the car wouldn't go into reverse i took apart the tranny and found out that the synchro for the 5th reverse gear was crushed and so was the reverse gear its self. Before i pulled it out i lost 5th bout 2 weeks later. Doubt it was because of the clutch jus fuked the reverse gear up some how.
Old May 15, 2005 | 09:17 PM
KekahaB18's Avatar
thanks alot, whats the cost u paid for the replace for the syncro and reverse gear
will rockit
May 7, 2015 08:00 PM
SynSterLove
Sep 29, 2012 03:17 PM
new_climber
Feb 19, 2011 02:25 PM
1hgej1
Mar 30, 2009 09:55 AM
ChrisSpade
Apr 22, 2006 10:16 PM
