Installing Rear Speakers on 91 DX?
Old May 15, 2005 | 03:47 PM
explictness's Avatar
Default Installing Rear Speakers on 91 DX?
Does anyone have any info on how to install rear speakers on a 91 DX? or is there any write up on this?
Old May 15, 2005 | 04:15 PM
93formula's Avatar
Default Re: Installing Rear Speakers on 91 DX? (explictness)
do you have the rear towers for the speakers???
Old May 15, 2005 | 05:11 PM
Default Re: Installing Rear Speakers on 91 DX? (93formula)
yeah i just checked. it doesnt have wires for speakers or anything. if it does i didnt seeit, i will take pics if u like.
Old May 15, 2005 | 05:25 PM
slywfbpsi's Avatar
Are you sure you don't have the wires back there for the speakers? They are usually inside of the taillight panel. I didn't use the rear speaker bracket, just cut out the holes with a jig, and screwed the speakers down.
Old May 15, 2005 | 05:36 PM
Default Re: Installing Rear Speakers on 91 DX? (slywfbpsi)
that's the thing, i don't think Dx's come with rear speakers only 2 fronts. Si's come with all 4 i think. correct me if i wrong. because diff models have diff features am i correct? i remember in a post when i had my civic and stuff that like, DX didnt have a clock, but the LX did, or w.e but yeah. i can take pics 2morrow if needed.
Old May 15, 2005 | 05:42 PM
bagpipe goatee's Avatar
it has the wiring there, but you may have to pull off some of the interior to get to it.
on dx's, speaker pods were an option, some had it, but most didn't.
if you just screw the speakers in without something around them, they'll sound like **** because the air is mixing from the backside of the speaker and the frontside, causing nothing but muddy, really quiet sound. believe me, i did it before.
either buy speaker pods, or better yet, make them yourself.
Old May 15, 2005 | 06:29 PM
slywfbpsi's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">it has the wiring there, but you may have to pull off some of the interior to get to it.
either buy speaker pods, or better yet, make them yourself.</TD></TR></TABLE>well, I have a rear cargo cover on my dx, so it doesn't sound muddy, but if you look around you can find speaker pods if you don't want to cut into your rear deck. I have a dx and the wires were behind the rear taillight cover.
Old May 15, 2005 | 06:46 PM
sorry, i misinterpreted what you said.
i thought you meant screw them into the sides where the speaker pods go
Old May 15, 2005 | 06:47 PM
Default Re: (slywfbpsi)
Where are they by the rear tail lights, what do they look like? Any pics? I'm not trying to do anything fancy, just want more speakers so i can have more sound and bass. -=D i will just probably set them up in the pod with some like protection from the back and then cover them with the stock cover. -=D i have 2 pioneer 6 and a half's in the front. -=D Sounds good, but i need somemore sound.
Old May 15, 2005 | 07:12 PM
b16std's Avatar
Default Re: (explictness)
bump i would like to know also...had to rujn my own wires , rather take them out and run the stock way...anyone have any pics? or diagram?
Old May 15, 2005 | 08:07 PM
slywfbpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness &raquo;</TD></TR><TR><TD CLASS="quote">Where are they by the rear tail lights, what do they look like? Any pics? I'm not trying to do anything fancy, just want more speakers so i can have more sound and bass. -=D i will just probably set them up in the pod with some like protection from the back and then cover them with the stock cover. -=D i have 2 pioneer 6 and a half's in the front. -=D Sounds good, but i need somemore sound.</TD></TR></TABLE>If you take the rear cover off where the tailights are at and look inside them, there will be like two wires not attached to anything in the compartment, the left and right sides have different color wires, so it makes it easy to connect them to the right wire i.e. (+, -), anyway mine were brown/gray, and green/gray on one side and black/gray, and red/gray on the other. or something to that effect.
Old May 15, 2005 | 08:11 PM
90sohcHATCH's Avatar
im pretty sure all 88-91 came w/ rear speakers already wired in??
Old May 15, 2005 | 08:21 PM
slywfbpsi's Avatar
Default Re: (90sohcHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sohcHATCH &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure all 88-91 came w/ rear speakers already wired in??</TD></TR></TABLE>are you talking about speaker wires already there? Or, speakers actually in place? Because I had no speakers in place, just wires.
Old May 16, 2005 | 09:17 AM
naw i hear that it was factory or dealer decision to put in rear speakers or not. They come with the pod but no speaker.
im talking about everything in particular. i will take a look for the wires. maybe i just didnt spot them. i will have pics up on everything later.
Old May 16, 2005 | 09:26 AM
2fast4udude's Avatar
the wires are under neath the rear deck lid... they're wrapped up around some other wires underneath there. i had no speakers in my 91 DX either, but i found the wires there, all i had to do was hook em up to the speakers (y)
i can get pics if you want, just not until tonight
Old May 16, 2005 | 09:29 AM
Bjorn20's Avatar
Default Re: (2fast4udude)
well 4 good speakers would be hela better than 2 specially in a small car. so ya pics would be nice, specially for a noob like me
Old May 16, 2005 | 09:30 AM
audioroach's Avatar
okay on both the crx's and the civics...the wire are there.
crx-remove rear speaker covers and look for a wire harness that taped to the body
or taped to anoth harness with blueish tape...this is your rear spaeker connection.
it located in the general are. Speaker brackets are needed to mount it...some bone yards are good choices or you can do dealerships parts dept or a car audio
retailers.
civics sedans...a lil more work is involved if you remove the rear deck its taped
to another harness...with blue tape...speaker brackets best but you can mount the
new speaker directly to the rear deck.
civic hatchs - as stated wire is near rear lights wrapped in blue tape- speaker brackets are a definate here.
laterz
Old May 16, 2005 | 09:31 AM
FalkenSiR's Avatar
How did you fit 6.5??? I know I heard of a mod at some point, is there any info floating around anyone could share?
Old May 16, 2005 | 09:34 AM
Bjorn20's Avatar
Default Re: (fast88std)
does it matter at all the size of the speakers? whats the standard size for a ef, or do u just put in w/e fits in
Old May 16, 2005 | 09:55 AM
EFB16ACRX
Guest
Posts: n/a
Default Re: (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">does it matter at all the size of the speakers? whats the standard size for a ef, or do u just put in w/e fits in</TD></TR></TABLE>6.5 is the stock hole size. or 5.75 or whatever, same thing. I have 5x7 in the back of mine, i cut up the mounting plate. 6x9 will also fit.
Old May 16, 2005 | 10:00 AM
naw i didnt have to mod it or anything, just had to cut off stock wires and put on the other ones that plug into t he speaker, took me and friends like 10 mins each speaker.
Old May 16, 2005 | 10:04 AM
Bjorn20's Avatar
Default Re: (EFB16ACRX)
hmm, im not going to have to mod anything to put new speakers in there will i? (front speakers) im having my dads friend come over and install a cd player and another speaker in my car since the 2 stock speakers that came with it, 1 of them was shot when i got it, but i didnt care sicne when im done with getting my car up to the speed i
want, ill start getting into the sound system and such.
i also heard that if u dont know what ur doing for wiring on hondas, u can serously **** up ur car. like they went cheap on it and have several things running on the same wire.
so if u cut something to change out the wires on ur headlight or something, u could end up taking out more than just that or w/e. dunno if thats true. but ya im done.
Old May 16, 2005 | 11:25 AM
6.5s fit, thats wat i hace in there.
its not hard to do, put the back seats down, lay underneath into the trunk, right below the deck lid, and the connectors are taped (yeh, with blue tape) to a bunch of wires wrapped in black tape... its REALLY hard to miss.
Old May 16, 2005 | 11:31 AM
Bjorn20's Avatar
hmm, so would the sound quality be different if u had a diff size speaker, or does it all have to do with watts? cause im really freakin confused about that. i have yet to take my back seat out yet
Old May 16, 2005 | 01:04 PM
Where are the wires located? Can u post pics up? i don't see them
