Overheating EG 100 Degree's Plus Outside : (
Old May 15, 2005 | 03:20 PM
r0cket247's Avatar
Default Overheating EG 100 Degree's Plus Outside : (
I recently bought a 94 Civic Coupe, at first the fan did not turn on after the car warmed up. I wired it to a switch, let the car warm up for twenty minutes and seemed fan. After that I drove my car down the block and it immediatly started overheating.
Now, the day I found out the car fan wasnt working was when I saw white smoke coming out the engine bay (Cluster Temp Needle Broken).
I also noticed a sizzling noise from the radiator cap after the car was turned off.
What can it be ?
Rad. Cap?
White Smoke = Headgasket no?
Thermostat?
Anyway way to test?
Old May 15, 2005 | 04:28 PM
Lmgrcivic's Avatar
Default Re: Overheating EG 100 Degree's Plus Outside : ( (r0cket247)
do you have enough coolant in the motor, your thermostat might not be opening
Old May 15, 2005 | 04:47 PM
OpTiX619's Avatar
Default Re: Overheating EG 100 Degree's Plus Outside : (Lmgrcivic)
fan, coolant, radiator cap, radiator (cracked), thermostat, water pump, head gasket
btw. my headgasket was blown in three cylinders. only sign of it was overflow was overflowin when i would drive the car hard.
Old May 15, 2005 | 07:07 PM
r0cket247's Avatar
Default Re: Overheating EG 100 Degree's Plus Outside : (OpTiX619)
Update :
Changed Thermostat and Gasket from Kragen Autoparts ... took longer to overheat
Fan is on
Noticed that Upper hose is hotter than lower
Changed cap .... still overheated
Checked oil and it is normal.
Hear like this szzzzzz noise coming from the rad. cap and sounds like by the engine .. where the dipstick is .. .to the far left????
Left cap of car to air out bubbles and ... smoke started coming out of the radiator .. white smoke. Had heater on too........
ANYONE?
Old May 15, 2005 | 07:11 PM
Deemeetree's Avatar
Electrician
You really need to use OEM parts on this one. Aftermarket caps and thermostats don't work too good at all, they sometimes come fucked from factory.
Do an entire overhaul.
Get yourself:
OEM thermostat
OEM radiator cap
OEM water pump
Change upper and lower hoses as well.
Bleed system properly and off you go.
BTW, DEFINITELY look into fixing your fan to come on when it's supposed to. Check if the wiring, fan, or thermoswitch is shot.
Old May 15, 2005 | 09:54 PM
r0cket247's Avatar
Default Re: (Dimitri_EG8)
What about the sizzling noise coming from where the upper radiator hose meets the engine ?
Bad Gasket ? There is no white smoke though . . .
Also noticed my radiator resivor has small dripping leak?
Dunno .. guys help me ou
Old May 16, 2005 | 06:00 AM
r0cket247's Avatar
Default Re: (r0cket247)
tttttttttt
Old May 16, 2005 | 06:06 AM
Lmgrcivic's Avatar
use all oem stuff and change the water pump and the sizzleing noise is your coolant boiling cause its so hot
Old May 16, 2005 | 06:10 AM
Deemeetree's Avatar
Electrician
Have you checked if there's any restriction in your hoses? Do a complete changeover. Flush the block out. Flush the radiator. Replace.
Lred1993civiccx
22
Jun 29, 2019 05:36 PM
Omega Blaze
Aug 20, 2016 01:48 PM
drshottest718
Sep 3, 2009 10:29 AM
coupon
Jul 21, 2005 10:42 AM
twenty
Jul 21, 2005 08:36 AM
