how much coolant needed in the cooling system?
Old May 15, 2005 | 03:01 PM
icedlee's Avatar
Default how much coolant needed in the cooling system?
i put a gallon of 50/50 after replacing the radiator. how do i know if its sufficient?
thanks,
Old May 15, 2005 | 10:21 PM
StorminMatt's Avatar
Default Re: how much coolant needed in the cooling system? (icedlee)
If the coolant level reaches the radiator filler while the bleeder is open. Just keep in mind that when you reach the top, you have to close the bleeder and pour in a small amount more to replace that which came out of the bleeder after you reached the top.
david90
Jun 10, 2021 07:42 PM
CDtegGo
Aug 27, 2006 02:22 PM
hbkxtbone
Jun 22, 2004 08:07 AM
MugenB16A2
Mar 2, 2004 07:48 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
