Front brake schimmy?
Old May 15, 2005 | 01:59 PM
Mr.Speed's Avatar
Default Front brake schimmy?
I have a 1993 Civic sedan and when you apply the brakes the front wheels scimmy it feels like the rotors are warped? The brakes grab and then don't grab as much the grab more again. I recently replace the pads and had the rotoras turned and then this started happening after about a month of driving any suggestions? i have check tire pressure that is not the problem.
Thanks
Old May 15, 2005 | 03:54 PM
alotawatts's Avatar
Default Re: Front brake schimmy? (Mr.Speed)
You did the brake work or had it done ?
Old May 15, 2005 | 04:01 PM
allmotorEG-SI's Avatar
make sure everything is bolted up properly and the caliper is in working order. Basicly just take the wheel off and look to see if you can find any problems first.
Old May 15, 2005 | 04:14 PM
jlacoy82's Avatar
71.192.16.183
Yeah, make sure the caliper mount bolts are tight and there isnt any obvious bad wear spots on the rotors/pads.
Old May 15, 2005 | 08:17 PM
Mr.Speed's Avatar
I have check everthing and it's all tight! Could the rotors warp?
Old May 15, 2005 | 09:54 PM
JohnnyWash1's Avatar
Default Re: (Mr.Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Speed &raquo;</TD></TR><TR><TD CLASS="quote">I have check everthing and it's all tight! Could the rotors warp?</TD></TR></TABLE>
Yes, rotors warp. Have your brakes checked by a shop---Midas and others do the check for FREE. What you are describing could be a few things (lines, hydraulic cylinder, rotors, etc.)---so make sure you have pros check it out in person, not over the net.
Old May 16, 2005 | 03:26 AM
turq93t's Avatar
I have always heard that overtightening your lug nuts will warp your rotors. It is always good to make sure they are torqued properly.
Joe
Old May 16, 2005 | 03:31 AM
Ajax's Avatar
Default Re: (turq93t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turq93t &raquo;</TD></TR><TR><TD CLASS="quote">I have always heard that overtightening your lug nuts will warp your rotors. It is always good to make sure they are torqued properly.
Joe</TD></TR></TABLE>
Really? I wonder if thats why my brakes are warped? I need to buy a torque wrench.
Old May 16, 2005 | 07:45 AM
Farmer Brown's Avatar
Default Re: (Ajax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyWash1 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, rotors warp. Have your brakes checked by a shop---Midas and others do the check for FREE. What you are describing could be a few things (lines, hydraulic cylinder, rotors, etc.)---so make sure you have pros check it out in person, not over the net.</TD></TR></TABLE>
Rotors are most likely warped. When you put new rotors on or freshly turned you cant drive them hard or they will warp.
This happened to me too.
swag
Apr 13, 2009 06:44 AM
jorge99hx
25
Dec 10, 2005 12:52 PM
EM1 Loi
Jul 15, 2005 12:24 PM
Vic_GSU
16
Jul 11, 2004 04:10 PM
95integrags-r
Jul 23, 2003 04:21 PM
