ACT CLUTCH LOW IDLE ????
hey i have a little problem.. when i push my clutch in the rpm drops down to like 500 and the car dies ..... What could that be ????? idle screw does nothing still drops low ????? thanks guys
bit difficult to explain but If you have a lightened flywheel your engine will find it harder to grip; if the clutch pedal is pressed the revs will drop down quicker than a stock flywheel due to weight.
At the moment i have the 7.5lbs fidanza flywheel, when i press down my clutch during roll it will drop to 200-300 rpm's.
Hope this helps.
Mohsin
Hope this helps.
Mohsin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">
So does that mean that your idle is lower than stock?
skUnK2jdm
May 25, 2008 05:18 PM
B18C GSR CIVIC
13
Apr 30, 2005 05:54 PM
