D16z6 straight T3 12psi....110mph
Old May 15, 2005 | 12:20 PM
Bailhatch's Avatar
Default D16z6 straight T3 12psi....110mph
What do you guys think this is capable of? I'm #089. Here's a thread about the setup too.https://honda-tech.com/zerothread?id=1246189
Old May 15, 2005 | 01:07 PM
Bailhatch's Avatar
Default Re: (Bean-Burrito)
Yes i had no idea what I was doing as far as the lights. The 13.1 pass was the 2nd pass of my life in anycar.Why does reaction time even matter if I'm just out to get good times? I really dont care how fast the other car is.
How do you figure that long tubular manifolds are only for big turbos? The advantages of long tube manifolds are just as usefull on a small T3 turbine. Fast spool up is not one of them. Short runner manifolds are for fast spool.
yes i need to work on traction. The wheel hop was horrible in 1st. I have done motor mounts and have all poly bushings up front. I plan on building traction bars soon also. Might have some drag radials I can use too.
If i ran 11s I would be stoked.
Old May 15, 2005 | 03:14 PM
Professor15's Avatar
You need to practice launching...you can improve your 60f/t a bit...
Old May 15, 2005 | 04:16 PM
SOHCboost's Avatar
nice setup... 60 fts are horrible.. get sum slicks and try again ...
Old May 15, 2005 | 04:23 PM
Bailhatch's Avatar
Default Re: (SOHCboost)
I'll borrow those drag radials and turn the boost up next time. I'll practice launching too. should be easy 12s with 10-20 more Hp and some practice.
Old May 15, 2005 | 05:43 PM
DeadVet's Avatar
Default Re: (Bailhatch)
ill let you use my BFGs and ill still beat you j/k
We have to go sometime soon
Old May 16, 2005 | 05:14 AM
vtekthis's Avatar
Default Re: (rota92)
Yes sleeping at the lights does not mean ****, Your 60 ft needs work, but you MPH is capable of a low-mid 12 sec pass
Old May 16, 2005 | 11:38 AM
alexsracing's Avatar
I got A 12.6@110 in my sohc w/ 14b eclipse turbo at 12 psi
Old May 16, 2005 | 11:49 AM
DeadVet's Avatar
Default Re: (alexsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing &raquo;</TD></TR><TR><TD CLASS="quote">I got A 12.6@110 in my sohc w/ 14b eclipse turbo at 12 psi</TD></TR></TABLE>
Drag radials or slicks?
Old May 16, 2005 | 12:41 PM
yokohama road race tires 20x8x13
im looking for some 22x8x13 m&h racemasters
Old May 16, 2005 | 06:51 PM
Bailhatch's Avatar
cool, thanks guys. I re-tuned already and it feels much better on its way to full boost. The power is so damn linear, like an NA motor, so I dont even spin 2nd but its way faster than my old T3 setups. Wants to rev way past 7500....stock head though
Modified by Bailhatch at 12:32 AM 5/18/2005
wfocrx
Jun 13, 2006 09:50 PM
djfob
Nov 1, 2004 08:29 AM
Bailhatch
Aug 29, 2004 08:16 PM
racinskittle
Jun 9, 2003 09:47 PM
