94' Integra Rear LCA bolt question
I just put my car back to stock suspension and on my rear passenger side shock I just think I might've put it on backwards because the lower portion where the LCA bolt goes in is not on the same side as the other shock. The shock is the opposite way around and the bolt is as well. Will this cause me a problem? Are the bolts OK to be put it on the opposite way?
I dont see a problem with this.... did it by accident once but reversed it afterwards.
If they have the welded nut towards the front of the car, they have it their for a reason. My guess would be for easier acsess if your doing a strut replacement just cause their is more room to get to the bolt head from the rear. Get what im saying???
turbotime
May 3, 2007 09:49 PM
