Help with hooking a UEGO to a p28
Old May 15, 2005 | 08:22 AM
Used2beAb16's Avatar
Default Help with hooking a UEGO to a p28
Running a p28 conversion on my obdII car. Right now i am having problems with my heated primary o2 sensor. I also have this AEM UEGO with display layhing here and i was considering replacing the stock primary o2 with the UEGO.
I believe i would have to set the gauge to nermst 0-1v output, since this is the stock o2 sensor output. Wideband is 0-5v, If i am running to the p28 with the 0-1 v, will it still be capable of outputting the wideband readings to the gauge? Or would i basically be running a reg old fashion narrow band gauge?
Old May 15, 2005 | 08:41 AM
mmuller's Avatar
Mad Scientist
Default Re: Help with hooking a UEGO to a p28 (Used2beAb16)
im not sure about the display, but i know that if you disable the o2 and o2 heater you can input 0-5v from the wideband into D-14, you would be able to datalog wideband output.
Old May 15, 2005 | 09:00 AM
Default Re: Help with hooking a UEGO to a p28 (mmuller)
Whoa, Im a little lost. Let me get a few things straight. IF i make a chip that disables the 02 and o2 sensor heater(it will be open loop then)
Now what do i do? How do i input to D-14? how do i log then?
Old May 15, 2005 | 09:31 AM
nevermind, I figured it out and that **** is all way above me.
ef9allday
Mar 22, 2013 09:46 PM
jerryscherry
Engine Management and Tuning
Dec 24, 2010 04:13 PM
ekcivic2
Jun 19, 2010 09:59 AM
civicious
Jan 6, 2006 10:25 AM
7rrivera7
Jun 8, 2003 01:22 PM
