Honda Oil filters the best? And what oil?
Old May 15, 2005 | 06:37 AM
turq93t's Avatar
Default Honda Oil filters the best? And what oil?
I am about the change the oil in my girlfriends newly bought 2000 Civic EX and am wondering if I should buy only Honda oil filters? Are they the better than the other off the shelf at the autoparts place, Fram, STP, etc...
Also with the car having 119,000 miles should I stick with the 5w30 oil that the manual recommends or go with 10w30 or higher? I always use Castrol.
Thanks
Joe
Old May 15, 2005 | 07:27 AM
deserthonda's Avatar
stick with honda filters they are only a few dollars more as for oil castrol if fine 5-30/ 10-30. if you live in real cold climate you might use 5-20 in winter the key to oil is to change it and filter every 2500 -3000 miles
Old May 15, 2005 | 07:30 AM
egsleepercivic's Avatar
if your not burning/losing oil stick with 5-30, filters are personal choice, I think the honda ones with the exception of the s2000 are made by fram
Old May 15, 2005 | 07:36 AM
DeadVet's Avatar
Default Re: (egsleepercivic)
fram is garbage......Wix
Old May 15, 2005 | 07:47 AM
HitEm'Up's Avatar
Default Re: (1TurboHatch)
Wix is the only replacement filter id buy for factory replacement, 5w30 is good for what you need too
Old May 15, 2005 | 07:50 AM
ZacCarter's Avatar
What is this wix you speak of?
Old May 15, 2005 | 07:54 AM
DeadVet's Avatar
Default Re: (ZacCarter)
brand of filters.....Napa filters are made by wix.
Old May 15, 2005 | 07:57 AM
ZacCarter's Avatar
So they are avalible at napa?
Old May 15, 2005 | 07:59 AM
DeadVet's Avatar
yup part number 1334
Old May 15, 2005 | 08:02 AM
ZacCarter's Avatar
Word i was gonna ask for a part number. Doesnt matter which motor does it, i got a b16 in the coupe.
Old May 15, 2005 | 08:03 AM
DeadVet's Avatar
what year did your b16 come from? or better yet whats the part number for your current oil filter?
Old May 15, 2005 | 08:05 AM
ZacCarter's Avatar
95 b16a3 out of the vtec sol.
Old May 15, 2005 | 08:07 AM
DeadVet's Avatar
yup same part number 1334
Old May 15, 2005 | 08:08 AM
ZacCarter's Avatar
Word.
Old May 15, 2005 | 08:10 AM
showbiz's Avatar
nippon filters rock... \mm/
Old May 15, 2005 | 08:25 AM
if you get the s2000 filter from honda it is a good jap made one for $8
Old May 15, 2005 | 10:56 AM
97civicdx's Avatar
I use Fram orange with the black grippy thing.
Old May 15, 2005 | 11:01 AM
Ben_si's Avatar
Holla back the black grippy thing on the fram's is ill
Old May 15, 2005 | 11:13 AM
ZacCarter's Avatar
fram is ****!
Old May 15, 2005 | 11:16 AM
Capt. Jimbo McSubipants's Avatar
never had a problem wtih fram
plus the black grippy thing is dope as hell
Old May 15, 2005 | 12:23 PM
havoc337's Avatar
Default Re: (b16delteg)
I heard a rumor that fram filters will clog your oil passages if you go too far beyond the 3000 mile mark. The dealership I work at now had to replace 2 engines so far and sent fram the bill. I think it had something to do with using a cardboard part instead of tin (like they used to) in order to make the filters more cost-effective. The cardboard breaks down and gets sucked into the engine, creating a blockage. ...then again, the engines that blocked up were Ford's...
Old May 15, 2005 | 12:28 PM
silverb18's Avatar
Default Re: (havoc337)
wix
Old May 15, 2005 | 12:32 PM
john d
Guest
Posts: n/a
Default Re: (silverb18)
fram
Old May 15, 2005 | 12:39 PM
92eh3si's Avatar
NAPA > FRAM
it has been tested before
Old May 15, 2005 | 12:44 PM
::MYCORD::'s Avatar
Default Re: (92eh3si)
Go to the dealership and get a s2000 filter. Best filter you can buy for your car. Also for oil just use castrol. Good stuff
