HELP!!!
Old May 14, 2005 | 08:43 PM
carlosd68's Avatar
Default HELP!!!
today i redlined 1st gear and when i tried throwing in 2nd gear i couldnt beacause my clutch never returned it was in the bottom........any body have an idea what this can be?
Old May 14, 2005 | 08:50 PM
slo97coupe's Avatar
Default Re: HELP!!! (carlosd68)
1st off check ur clutch fluid.... if its low its obvious ur out but as to why ur out...
if u r low on fluid no worrys just get some fluid and a bleed it but to fix ur problem check to see if u see any fluid around the master cylinder... if theres none scheck ur slave cylinder its probably that... its cheap and it wont take long to install ..
if not that i unno ....
Old May 14, 2005 | 09:03 PM
carlosd68's Avatar
i checked my fluid and its good
Old May 14, 2005 | 09:10 PM
slo97coupe's Avatar
hmm did the peddell ever come back up or did it stay down?
Old May 14, 2005 | 09:14 PM
Luserkid's Avatar
Default Re: (ek97-DAP)
If it stayed down then you have air in the line, and you need to bleed it.
Old May 14, 2005 | 09:24 PM
logikalfury's Avatar
i had my slave cylinder replaced last year for this problem, and about 3 weeks ago i had the same troubles, but this time it was only the clutch fluid level
Old May 14, 2005 | 10:14 PM
carlosd68's Avatar
the pedal stayed down but the weird thing is that it only does it when i floor the car
deeweezy187
Jan 5, 2008 10:04 AM
b16pwrdeg
Dec 31, 2006 06:49 AM
tytyguy
Dec 3, 2005 02:32 AM
R.a.w.
May 18, 2005 03:41 PM
allmotor.net
May 23, 2004 08:53 PM
