UKDM cluster problem / question
Old May 14, 2005 | 06:54 PM
d357r0y's Avatar
Default UKDM cluster problem / question
I just installed the 9500rpm tach and 150mph speedo into my SI cluster housing..
Everything works but it seems like my speedometer is reading about 10mph too high.
Anyone else have this problem or know if a fix?
TIA
Old May 14, 2005 | 07:12 PM
CRX_Control's Avatar
Default Re: UKDM cluster problem / question (d357r0y)
doesnt the cluster read in kph?
Modified by CRX_Control at 12:25 AM 5/15/2005
Old May 14, 2005 | 07:48 PM
d357r0y's Avatar
Default Re: UKDM cluster problem / question (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">doesnt the cluster read in kph?
Modified by CRX_Control at 12:25 AM 5/15/2005</TD></TR></TABLE>
Primary is MPH secondary is KPH
Old May 14, 2005 | 07:51 PM
Bjorn20's Avatar
that cluster would be like perferct for me, only thing that would beat it is a digital or one that goes to 10k rpms and is still in mph
Old May 14, 2005 | 07:59 PM
d357r0y's Avatar
Default Re: UKDM cluster problem / question (Bjorn20)
10-4 on that..
so far it's nice, kinda odd getting use to the tach needle's location at RPMs.
bump for help?
Old May 14, 2005 | 08:23 PM
crxgator's Avatar
mine was fine...dont know what to tell you man...
looks like your cluster is broken? your mileage shouldnt be like that in the middle...thats pretty fucked up...
Old May 14, 2005 | 09:35 PM
Louie B.'s Avatar
Default Re: UKDM cluster problem / question (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">mine was fine...dont know what to tell you man...
looks like your cluster is broken? your mileage shouldnt be like that in the middle...thats pretty fucked up... </TD></TR></TABLE>
It should straighten itself out when it flips to 101,000
Old May 15, 2005 | 08:43 AM
d357r0y's Avatar
Default Re: UKDM cluster problem / question (Louie B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie B. &raquo;</TD></TR><TR><TD CLASS="quote">
It should straighten itself out when it flips to 101,000</TD></TR></TABLE>
Yeah, thats what I was thinking too. on my old cluster it gets all cockeyed when it's getting ready to roll over.
Anymore suggestions on my MPH problem?
Old May 15, 2005 | 08:57 AM
crxgator's Avatar
i guess, it just looks like it is too early to get cockeyed like that...look it the fuel mileage counter...see how the 6 isnt even moved yet and its on 8/10 of a mile...
Old May 15, 2005 | 09:08 AM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">i guess, it just looks like it is too early to get cockeyed like that...look it the fuel mileage counter...see how the 6 isnt even moved yet and its on 8/10 of a mile...</TD></TR></TABLE>
Yes, I did notice that too. I think I need to drive and find the police "your speed" radar station.
Old May 15, 2005 | 12:03 PM
crxgator's Avatar
here is mine...see, it should still not be near turning...
Old May 15, 2005 | 12:07 PM
92civicfreak's Avatar
if u get caught speeding just blame it on the speedo
Old May 15, 2005 | 02:02 PM
d357r0y's Avatar
Default Re: (92civicfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicfreak &raquo;</TD></TR><TR><TD CLASS="quote">if u get caught speeding just blame it on the speedo</TD></TR></TABLE>
I'm not worried about speeding or getting caught doing it, I just like my stuff to work 100% correctly.
Old May 15, 2005 | 02:17 PM
ukdm crx's Avatar
Then you'll get a fix it ticket and a speeding ticket, think boy think.
Old May 15, 2005 | 02:41 PM
d357r0y's Avatar
Default Re: (ukdm crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ukdm crx &raquo;</TD></TR><TR><TD CLASS="quote">
Then you'll get a fix it ticket and a speeding ticket, think boy think.</TD></TR></TABLE>
Yeah..32 and no speeding tickets so far!
I gotta figure out a fix for this **** or I'm selling it.
Old May 15, 2005 | 05:32 PM
d357r0y's Avatar
just went out for a test drive again to check the speed.. the clock reads 75mph and i'm going roughly 60.
suggestions?
is calibration possible?
Old May 15, 2005 | 06:04 PM
Louie B.'s Avatar
If it's off by exactly the same amount at every speed then you can just carefully pry the speedo needle off and re-install it at the correct position.
If it becomes further off the faster you go then it's a gearing issue. are you sure your old speedo was dead on? are you running factory size wheels/tires?
Old May 15, 2005 | 06:11 PM
d357r0y's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie B. &raquo;</TD></TR><TR><TD CLASS="quote">If it's off by exactly the same amount at every speed then you can just carefully pry the speedo needle off and re-install it at the correct position.
If it becomes further off the faster you go then it's a gearing issue. are you sure your old speedo was dead on? are you running factory size wheels/tires?</TD></TR></TABLE>
I can't reinstall it 15mph lower because it sits at zero at a stop (though, when coming to a stop the needle drops very slowly down to zero). My old one was within 1 mph as checked by the police radar boxes on the road sides. ls/gsr wheels with 195/50 tires (a lottle worn down) but certainly not enough to thow it off that much. Also. it's reading on the trip reset correctly. 1 mile is one mile..so it's mechanically counting correctly, but the electric part of it is not working properly.
Old May 15, 2005 | 09:23 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">(though, when coming to a stop the needle drops very slowly down to zero)</TD></TR></TABLE>
that sounds like it's binding/rubbing on something. you could take it apart and see if you can figure out what it's rubbing on.
Old May 16, 2005 | 08:48 AM
d357r0y's Avatar
that sounds like it's binding/rubbing on something. you could take it apart and see if you can figure out what it's rubbing on.</TD></TR></TABLE>
I'll try that.. the only reason that doesn't make sense is that if it was binding it should keep it from reading high and read lower than actual instead.
Thanks for the suggestion.
Old May 16, 2005 | 10:02 AM
d357r0y's Avatar
Well.. just incase anyone cares...
I just cracked this thing open and someone has definitely been ******* around with the odometer
one of the "teeth" that holes the numbers in place was bent and a washer has obviously been tampered with to roll it back.
Hopefully putting everything back in place will solve the problem.
aziaticvang
Jan 8, 2008 06:41 PM
Ryan.
Oct 30, 2007 06:46 AM
thisboyjulio
Sep 5, 2007 05:42 PM
