Idle problem with ITBs and AEM EMS
My idle is unable to hold if creeping through traffic, small throttle change would cause the engine to stall. Very annoying when parking and going uphill, I have adjusted the target rpm but still couldn't adjust the rpm higher at idle, my ITBs have been adjusted to open slightly at idle, and my injectors have been inputted in the EMS. Im trying to find ways to increase the rpm of the idle, or at least maintain the rpm at sudden low throttle. My idle is now at 900-1100, sudden change of throttle will drop the rpm down and stall, any help is appreciated.
I am not familiar with the EMS software, but Hondata has a throttle tip in adjustment. The EMS should have something similar-just fatten it up on tip in and see if it helps. Or you could hit up Jdogg or any other EMS tuner for tips.
let me take a look at your calibration and see how its setup, most likely you havent found your key AFR and idle point with those cams. how is your vacuum setup done?
TB123
Jul 3, 2014 07:38 PM
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
