Fuel Pressure Regulator Necessary??? With these mods
Old Feb 4, 2002 | 08:43 PM
_unknown_'s Avatar
Default Fuel Pressure Regulator Necessary??? With these mods
I am just trying to find out once and for all, whether a FPR is necessary or not.
My future engine mods:
B18C-5 Motor (w/ Stock Cams)
CTR Pistons (.25 over)
Toda 1.0mm Headgasket (should yield 12.0-1)
Cam Gears
I will be getting a chipped ECU by Erick's Racing. I will also be using a V-AFC.
Is a fuel pressure regulator necessary? If so, I don't like B&M products so what kind do you suggest? Sard??? Aeromotive??? Paxton???
TIA
Old Feb 4, 2002 | 09:08 PM
sgT's Avatar
sgT
Default Re: Fuel Pressure Regulator Necessary??? With these mods (spoonek9)
Cam Gears
i wouldnt get the head gasket. Otherwise you might as well not get the CTR pistons.
But yeah you will want either larger injectors, FPR, or BOTH.
Old Feb 4, 2002 | 09:22 PM
_unknown_'s Avatar
Default Re: Fuel Pressure Regulator Necessary??? With these mods (sgT)
Thanks for the quick response Sgt.
Yeah, about the Toda headgasket, I am probably going to use a stock one in the end.
What size injectors do you recommend? Do you recommend an upgraded fuel pump as well?
TIA
[Modified by spoonek9, 10:23 PM 2/4/2002]
vtibrazil
Nov 12, 2004 03:43 PM
CivicTypeR00
Jan 14, 2004 10:14 PM
McFly
Mar 5, 2003 08:09 PM
KJ
Oct 6, 2001 02:17 AM
