CTR Piston Questions
Old Oct 5, 2001 | 01:20 PM
KJ's Avatar
KJ
Default CTR Piston Questions
Hi, would you need to change fuel injectors if you get CTR Pistons and put them into an ITR engine? Also, would you need to get your ECU Reprogrammed to handle the increased compression?
Thanks,
KJ
Old Oct 5, 2001 | 01:37 PM
ITR111's Avatar
New User
Default Re: CTR Piston Questions (KJ)
what cams r u using??
if you using some big cams, you should change injectors and reprogrammed ECU
EVOCELICA's Avatar
New User
You don't need to but it would be smart CTR's in a ITR motor will yield high compression numbers and knock with follow unless you have the proper fuel delievery.
Old Oct 5, 2001 | 01:39 PM
ITR111's Avatar
New User
Default Re: CTR Piston Questions (EVOCELICA)
yupyup
if you are using stock cams, i think just reprogrammed ecu or VAFC is ok
Old Oct 5, 2001 | 03:10 PM
KJ's Avatar
KJ
Default Re: CTR Piston Questions (ITR111)
Yes, I'm using stock cams.
Do I need injectors? Or can I just increase fuel pressure and lean out the mixture where I have to with the V-AFC?
Old Oct 5, 2001 | 04:21 PM
ITR111's Avatar
New User
Just get a Fuel pressure regulator and VAFC should do it
i dun know whether you should lean out the mixture or not. But i want to know too since i want to get some toda pistons, i think if u lean out it will knock
[Modified by ITR111, 1:23 AM 10/6/2001]
Old Oct 5, 2001 | 06:34 PM
KJ's Avatar
KJ
The reason for getting the fuel pressure regulator is because the V-AFC can't really add fuel, so you use the fuel pressure regulator to make it RICH EVERYWHERE on the powerband and then use the V-AFC to lean it out where you need to.
Old Oct 5, 2001 | 07:52 PM
ITR111's Avatar
New User
are you planning to change cams?
Old Oct 5, 2001 | 11:34 PM
KJ's Avatar
KJ
No, I'm planning to sell my car so I'm only doing the pistons because I need new ones anyway.
Old Oct 6, 2001 | 12:52 AM
jimbob's Avatar
New User
KJ! U selling your car? How come? Thought you were going to keep it as a winter car?!
Old Oct 6, 2001 | 02:17 AM
KJ's Avatar
KJ
Default Re: CTR Piston Questions (jimbob)
Hey man, long time no talk!
Message me on ICQ (I'm using a different computer now), I'll tell you the details. hehehe
Later man
crashzerothree
Jan 9, 2007 02:18 PM
p0gi_b0i_integra
Oct 25, 2006 09:44 AM
Dammit_Dan_954
Jan 27, 2004 10:05 AM
oryanh
Mar 25, 2003 03:57 PM
_unknown_
Feb 4, 2002 09:22 PM
