broke my knock sensor installing hondata gasket...should this effect my idle?
Old May 14, 2005 | 01:33 PM
Ministry's Avatar
Default broke my knock sensor installing hondata gasket...should this effect my idle?
I'm having a terrible day. I pulled my manifold to install a hondata heatshield gasket, and broke the plastic housing and plug off of my knock sensor. When I put everything back together, the idle was surging up and down between 1000-3000RPM.
could this have anything to do with my knock sensor being unplugged/broken?
trying to determine if I screwed something else up or if this is related to the knock sensor. All the vacuum hoses are connected and all the plugs seem to be in place.
TIA
Old May 14, 2005 | 01:45 PM
AndyD's Avatar
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (dreamer)
I believe it is due to a vacuum hose that is not hooked up properly on the IM. That happened to me after I did my H22 swap.
Old May 14, 2005 | 01:53 PM
Ministry's Avatar
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (AndyD)
thats what I thought but I checked 3 or 4 times and they seem to all be hooked up
Old May 14, 2005 | 02:21 PM
Ministry's Avatar
ok I fixed the idle. apparently I didn't torque down the nuts on the IM properly . I suck so bad today. sorry guys
so what happens if I drive around with an unplugged KS? is my ecu gonna pull timing or go into limp mode?
Old May 14, 2005 | 02:27 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">ok I fixed the idle. apparently I didn't torque down the nuts on the IM properly . I suck so bad today. sorry guys
so what happens if I drive around with an unplugged KS? is my ecu gonna pull timing or go into limp mode? </TD></TR></TABLE>
How do you feel after you installed the gasket? Feel any gain or decrease in temp under the hood?
Old May 14, 2005 | 03:14 PM
Ministry's Avatar
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">How do you feel after you installed the gasket? Feel any gain or decrease in temp under the hood?</TD></TR></TABLE>
the gasket doesn't effect under hood temps, it just keeps your IM from getting as hot. so no I haven't noticed any difference.
anybody ever try running an OBDI p13 with the knock sensor unplugged?
Old May 14, 2005 | 03:38 PM
Hawkze_2.3's Avatar
I broke my KS the same way a while ago and all that really happened was the CEL.
Old May 14, 2005 | 05:20 PM
Ministry's Avatar
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (Hawkze_2.3)
I drove the car around with the KS unpluged...got the CEL code 23 and the timing was retarded. lost lots of power.
then I went back and took a really close look at the KS. discovered that nothing really "broke," the plastic housing and the plug were just seperated from the metal sensor. I just kinda stuck it back together and went for a drive and it ran great, no code 23! I stuck some high temp silicone on/in their, hopefully it won't come loose. I guess I'm lucky?
well, the simple IM gasket install ended up taking like 5 hours. what a waste of a day. this thread is kind of a waste too I guess, since it only serves to document my mistakes. maybe somebody will read this and avoid the mistakes I made
Old May 15, 2005 | 06:45 AM
dmxsoulja3's Avatar
166 bucks for a new ks at honda, and yes it will put the ecu in limp mode.
Old May 15, 2005 | 09:00 AM
prelittlelude's Avatar
with the knock borken your going to throw a CEL and the ecu is going to dump a **** tone of fuel and pull a **** ton of timign, the car will feel like a dog and your going to burn thru gas
been there done that, get it fixed asap
Old May 15, 2005 | 09:01 AM
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (dmxsoulja3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmxsoulja3 &raquo;</TD></TR><TR><TD CLASS="quote">166 bucks for a new ks at honda, and yes it will put the ecu in limp mode.</TD></TR></TABLE>
thats not 100% true, when the ecu is in limp mode it has a lowered redline, depending on the mode its in it can be as low as 2500rpm rev limit in limp mode..
with the knock sensor gone the car kinda freaks but doesn't go into limp mode, it just adds alot of fuel and pulls timing but everything else works fine including vtec all the way to redline
Old May 17, 2005 | 05:10 AM
Ministry's Avatar
Default Re: broke my knock sensor installing hondata gasket...should this effect my idle? (prelittlelude)
so the ghetto rigged KS seems to be holding together, no CEL. but it feels like the ecu might still be pulling timing when I mash on the gas. can a KS function improperly and still cause no CEL?
Old May 17, 2005 | 10:03 AM
flip1199's Avatar
i broke my ks when installing my i/m. good thing i am running hondata and hondata doens't use the ks.
Old May 18, 2005 | 03:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreamer &raquo;</TD></TR><TR><TD CLASS="quote">so the ghetto rigged KS seems to be holding together, no CEL. but it feels like the ecu might still be pulling timing when I mash on the gas. can a KS function improperly and still cause no CEL?</TD></TR></TABLE>
i don't know how you gheto rigged it but the sensor coud be causing false knock because it is now fucked , and the ecu will pull timend and add fuel without telling you
Kayronn Grier
Dec 3, 2015 06:24 AM
Civic082382
Oct 23, 2010 05:41 PM
mien_civic715
Aug 25, 2010 06:12 AM
c1civic
Jun 19, 2007 11:17 AM
TurbodTegSfaria
Feb 27, 2007 03:57 PM
