Skunk2 stage 3's (not stage 2's!!)
Old May 14, 2005 | 12:42 PM
IggyBcool's Avatar
Default Skunk2 stage 3's (not stage 2's!!)
i have searched for stage 3's but when i search all that comes back are stage 2's. my questions are:
How much of a difference is there between the stage 2's and the 3's?
How streetable are the 3's?
How realiable are the 3's?
Would jdm itr pistons bump up the compression enough to get most potential out of these?
Who has a set and how do you like them?
i now currently have a 95 GSR (obd1) and im wanting to build the head. yes i know that i have to do valves, valve springs, retainers ect but i wuz wondering about these cams particurally. thanks for the help
Old May 14, 2005 | 01:12 PM
silversly's Avatar
BANNED
Default Re: Skunk2 stage 3's (99whitejizzer)
Im running 3's in my car right now and i dont think ur ITr pistons can handle the lift of the cams they are too big for your motor. You should stick with skunk 2s. The 3's are streetable and pretty reliable if you ask me. So, you need a GANK of compression to run those cams.
Old May 14, 2005 | 01:24 PM
IggyBcool's Avatar
would ctr's be good enough? 12:1 comp
Old May 14, 2005 | 01:47 PM
silversly's Avatar
BANNED
Default Re: (99whitejizzer)
are ctrs 12:1? im at 12.5 and they work great 85 mm bore though
Old May 14, 2005 | 01:51 PM
xEnderx's Avatar
Default Re: (ml2Voeg6)
How do you think they would work in a stock CTR motor?
Old May 14, 2005 | 02:13 PM
wrXtian's Avatar
Default Re: (xEnderx)
yeah i was considering 3's for a while, but the 2's seem to be best w/ oem pistons
Old May 14, 2005 | 03:22 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">How do you think they would work in a stock CTR motor?</TD></TR></TABLE>
Shitty, stick with stage 2's at the most
Old May 14, 2005 | 03:49 PM
IggyBcool's Avatar
what are some good cams that will pull hard and wont fall off and still rev to 10k? iv done a little more searching on the web and iv found out that streeting the stage 3's arent that good on the engine and spoon cams arent that aggressive. any other suggestions?
Old May 14, 2005 | 03:52 PM
Professor15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99whitejizzer &raquo;</TD></TR><TR><TD CLASS="quote">what are some good cams that will pull hard and wont fall off and still rev to 10k? iv done a little more searching on the web and iv found out that streeting the stage 3's arent that good on the engine and spoon cams arent that aggressive. any other suggestions?</TD></TR></TABLE>Jun's, buddy club's, toda's Rm...there are alot of choices out there and why do you want to rev to 10k?
Old May 14, 2005 | 04:00 PM
IggyBcool's Avatar
the mad vtakk dog... i dunno its just something about hearing a vtec bseries rev way the hell up there
Old May 14, 2005 | 04:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99whitejizzer &raquo;</TD></TR><TR><TD CLASS="quote">the mad vtakk dog... i dunno its just something about hearing a vtec bseries rev way the hell up there</TD></TR></TABLE>LOL...good joke...now really why do you want to rev to 10k?
Old May 14, 2005 | 04:22 PM
IggyBcool's Avatar
i mean one when revving up there ur going to get a higher speed and when u shift its gonig to land u back down in the power band causing it not to lag as much. also revving longer without having to shift as much
Old May 14, 2005 | 04:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99whitejizzer &raquo;</TD></TR><TR><TD CLASS="quote">i mean one when revving up there ur going to get a higher speed and when u shift its gonig to land u back down in the power band causing it not to lag as much. also revving longer without having to shift as much</TD></TR></TABLE>Revving that high will cause more stress on your motor and if your are not making power all the way to 10k there is no point, I hope you have a well built bottom end that can withstand 10k rpms...
Old May 14, 2005 | 04:35 PM
chameleon's Avatar
Default Re: (drchulo)
lol...10k after he throws a couple of rods through the block he'll be back down to 8k ..lol
Old May 14, 2005 | 04:37 PM
IggyBcool's Avatar
no im wanting to rebuild the whole engine completely so it will withstand these harsh revvings. but im not going to take it all the way to 10k every time i decide to get on it though
Old May 14, 2005 | 04:41 PM
Default Re: (chameleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon &raquo;</TD></TR><TR><TD CLASS="quote">lol...10k after he throws a couple of rods through the block he'll be back down to 8k ..lol</TD></TR></TABLE>some people really do choose to learn the hard way.
Old May 14, 2005 | 05:57 PM
UncleD's Avatar
The S2S3's are one of the most streetable camshafts out there. The primaries are no bigger than a stock type r cam. They idle like stock, puttin around town is like stock, but when vtec engages it really lets loose. If you're wanting to put pct pistons in your gsr motor, it will give you enough compression for those cams, <U>however</U> you might run into piston/valve clearence. You said earlier that you "know you need to do valves." I personally would NOT do valves with that much lift. If you're looking for additional options I would suggest thr RM M22's. They have allot of duration that will extend the power band. No matter what camshaft you do, I would buy the RM valvetrain though, especially since you're wanting to rev to 10k. Hope this helps..
alexthegrinch
13
Jun 17, 2009 05:08 PM
bigz187
Jun 11, 2005 07:22 AM
IggyBcool
May 14, 2005 01:56 PM
vtec_fox
Apr 1, 2004 07:16 PM
10K2HVN
Jan 15, 2003 11:06 AM
