Brake Bleeding Sequence?
On my GSR with ABS the sequence was RR, LF, LR, RF
Is this sequence the same if you have an RS non-abs proportioning valve to eliminate the ABS?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">I normally do the furthest from the master cylinder, RR, LR, FR, FL</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECAcuraGSR »</TD></TR><TR><TD CLASS="quote">On my GSR with ABS the sequence was RR, LF, LR, RF
Is this sequence the same if you have an RS non-abs proportioning valve to eliminate the ABS?</TD></TR></TABLE>
That's the sequence that is recommended for my CRX w/o ABS.
RR and FL are on the same circuit and LR and FR are on the same. Do the furthest from the MC in the circuit to the closest...whether you want to do both rear and then both fronts or whatever..doesn't really matter
nikolai.
12
Nov 12, 2006 08:51 AM
Lightning Orders
Jun 30, 2004 05:08 PM
