Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake Bleeding Sequence?
Old May 14, 2005 | 11:19 AM
VTECAcuraGSR's Avatar
Default Brake Bleeding Sequence?
On my GSR with ABS the sequence was RR, LF, LR, RF
Is this sequence the same if you have an RS non-abs proportioning valve to eliminate the ABS?
Old May 14, 2005 | 02:07 PM
JDM Factor's Avatar
I normally do the furthest from the master cylinder, RR, LR, FR, FL
Old May 15, 2005 | 09:45 AM
BlueTeg's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">I normally do the furthest from the master cylinder, RR, LR, FR, FL</TD></TR></TABLE>
x2
Old May 15, 2005 | 09:49 AM
FlyZlow's Avatar
Default Re: Brake Bleeding Sequence? (VTECAcuraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECAcuraGSR &raquo;</TD></TR><TR><TD CLASS="quote">On my GSR with ABS the sequence was RR, LF, LR, RF
Is this sequence the same if you have an RS non-abs proportioning valve to eliminate the ABS?</TD></TR></TABLE>
That's the sequence that is recommended for my CRX w/o ABS.
Old May 15, 2005 | 12:58 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Brake Bleeding Sequence? (FlyZlow)
RR and FL are on the same circuit and LR and FR are on the same. Do the furthest from the MC in the circuit to the closest...whether you want to do both rear and then both fronts or whatever..doesn't really matter
sh4mr0ck
Jul 23, 2009 07:21 AM
nikolai.
12
Nov 12, 2006 08:51 AM
g2_teg_
15
Oct 17, 2006 11:49 AM
Lightning Orders
Jun 30, 2004 05:08 PM
