Spearate the Transmission from Block (How)
Old May 14, 2005 | 07:40 AM
GsRHatchy1320's Avatar
Default Spearate the Transmission from Block (How)
how do u separate the block from the trans? (Gsr) im getting my block sleeved and i cant get it to separate from the trans. The motor is out of the car, the trans and block still together. A litte help would be appreciated thanx!
Old May 14, 2005 | 07:45 AM
rainforest's Avatar
Default Re: Spearate the Transmission from Block (GsRHatchy1320)
use a small flat-head screwdriver to open it slightly then pry the 2apart. make sure that all the bolts are disconected
Old May 14, 2005 | 07:55 AM
ok thanx. i tried using a pry bar first still no movement, all bolts are out. But ill try the screw driver
Old May 14, 2005 | 07:58 AM
rainforest's Avatar
Default Re: (GsRHatchy1320)
well if you have a pry bar just start it with a screwdriver then pry
eg:R
Apr 19, 2014 08:56 AM
Swiss Gary
Mar 17, 2007 05:54 AM
K_KrazyAzn
Dec 15, 2005 11:37 PM
integraboosted
May 25, 2005 02:52 AM
