Fixed TPS/EGR but broke this off...anyone know what is it / what it does?
Old May 13, 2005 | 11:00 PM
red92accord's Avatar
Default Fixed TPS/EGR but broke this off...anyone know what is it / what it does?
Hey guys, I've finally cleaned out my EGR ports and all that good stuff, but when i was pulling those taps out i accidently broke a piece of manifold that holds this valve. I'm not sure what this valve does, but it's got some kind of spring behind it, that opens it and closes it? Now I've used some JB Weld to stick it back in place but not sure if that will hold. Now my questions is what is this part, what's it used for, does it need to be in original place as it was or can It be anywhere to function? Here are the pictures of that piece I broke off
http://img223.echo.cx/img223/1608/engine9qd.jpg
http://img223.echo.cx/img223/3575/engine21bv.jpg
Old May 14, 2005 | 06:25 PM
TxTuner
Guest
Posts: n/a
Default Re: Fixed TPS/EGR but broke this off...anyone know what is it / what it does? (red92accord)
theres your pics
Old May 14, 2005 | 10:57 PM
Eddiebx's Avatar
thats ur IAB vacuum diaphram, its not essential for your car to run, but that jbweld does look like it will fall off eventually.
what I would do is just pull out the entire plate, then bolt the top of the manifold to the runners directly, with shorter bolts
Old May 14, 2005 | 11:46 PM
O3DigitalBath's Avatar
Default Re: (Eddiebx)
blah if you broke it just take it out...you don't really need it anyway
boostedBLUfg2
Feb 21, 2011 08:28 PM
emotionisdead
32
Jul 1, 2008 12:01 AM
JDM95lude
Oct 14, 2006 08:21 AM
delslo93
16
Apr 28, 2005 08:23 PM
a1320honda
May 3, 2004 12:06 AM
