Suspension & Brakes Theory, alignment, spring rates....
Correct rear tie-bar + LCA combo
Old May 13, 2005 | 09:10 PM
CarbonCreations's Avatar
Default Correct rear tie-bar + LCA combo
I'm currently building my lil EG from the ground up... planning on running with K-Sport 11k f/7k r setup. The car is a DX, so obviously I need to change out the LCA's to run a tiebar. My goals for the car is 220whp with a smaller turbo (this is a d16y7 btw... 60k miles) and to have a tight responsive car. I would appreciate some opinions that explain what and why will be the best combonation.. I don't really want to spend more than 350$, but I'll entertain all combo's
Old May 14, 2005 | 10:44 AM
Default Re: Correct rear tie-bar + LCA combo (CarbonCreations)
Old May 14, 2005 | 07:33 PM
dohcdelsol's Avatar
You do not need to get different lca's if you plan on running a tie bar. I think you mean a sway bar? Im personally running GSR lca's so i can run any sway bar.
Do a search, so many different combos.
Old May 14, 2005 | 07:48 PM
.RJ's Avatar
.RJ
OEM LCA's are fine (and cheap) and proven.
Old May 16, 2005 | 12:26 AM
Default Re: Correct rear tie-bar + LCA combo (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">You do not need to get different lca's if you plan on running a tie bar. I think you mean a sway bar? Im personally running GSR lca's so i can run any sway bar.
Do a search, so many different combos.</TD></TR></TABLE>
Yup meant sway bar. After a lot of reading... I'm going to do what everyone does... experiments
$MIKE$
Suspension & Brakes
12
Dec 29, 2013 06:51 AM
918eg
Sep 4, 2008 02:05 PM
whiteciv88
10
Dec 29, 2007 07:30 PM
20ls01
Feb 20, 2007 02:06 PM
Skeletor
10
May 20, 2003 06:22 PM
