car does move when in gear?
Old May 13, 2005 | 08:07 PM
t0ekn3e's Avatar
Default car does move when in gear?
i just replaced an axle on my car (passenger side) and now my car goes in to gear and everythign fine but it wont go anywhere, when i rev up the mph moves along with my tach. i recently repaced the axle becuase the axle got pulled out due to my car not having a cotter pin on the knuckle and the castle nut came off. (didnt know i didnt have a cotter pin). any help would be great thanks in advance.
Old May 13, 2005 | 09:43 PM
nocturnaldragon's Avatar
Default Re: car does move when in gear? (t0ekn3e)
Sounds like the axle isn't in all the way. The torque from the tranny will goto the side with the least resistance aka an axle not seated properly hence the car going no where. Since the tranny worked before you changed the axle. Id sagest that first.
Old May 13, 2005 | 09:47 PM
t0ekn3e's Avatar
so just take it apart and push it in more pretty much?
Old May 13, 2005 | 09:49 PM
Default Re: (t0ekn3e)
pretty much, it should sit flush with the trany housing aka no gaps. you may have to ratate it a bit to get it in there right if the spines on the axel and diff are hitting. They can be a bitch sometimes, the cotter pin has been known to fight you at times as well. Thats what fought me when i replaced my tranny.
Old May 13, 2005 | 09:53 PM
t0ekn3e's Avatar
ariite checked the axle and there is a gap imma push it back in in the morning cuz my moms car in the garage now also thanks man
Old May 13, 2005 | 09:58 PM
97hb's Avatar
Could also be an exploded diff, same symtoms as yours. If there is a gap, tranny fluid should be leaking out. Axles will click in when seated. There is a little ring on the end of the axle, make sure its there.
Old May 13, 2005 | 10:03 PM
Default Re: car does move when in gear? (97hb)
Mine only leaked after driving a while with them not being in all the way.
Old May 13, 2005 | 10:20 PM
t0ekn3e's Avatar
i cant even drive mine, exploded diff that sound bad i hope i dont have that no money to fix nothing in debt now getting another axle
Old May 13, 2005 | 10:40 PM
I feel for you buddy!
try turning your other axle for the hell of it, it should spin freely if not theres a good posibility your diff is messed up. I doubt it tho but I dont know without looking at the tranny myself. There extremly easy to change tho once you get the tranny out along with the tranny apart.
Old May 13, 2005 | 11:00 PM
t0ekn3e's Avatar
i rolled down my drive way with no problem so i think its fine i tried push starting since my battery is dying on me
Old May 13, 2005 | 11:26 PM
Could still be something messed up internally. I don't really have any other suggestions for you unfortunately. Hopefully someone else with more knowledge will chime in. Good luck
Old May 14, 2005 | 09:41 AM
92civicb18b1's Avatar
Default Re: (nocturnaldragon)
wait so what happened...
Did you fix your problem.
My diff in my GSR trans is garbage, actually I found nice chunks of it when I opened the case. It still works but grinds like crazy in any gear.
Old May 14, 2005 | 11:28 AM
t0ekn3e's Avatar
havent fixed yet about to this afternoon when my buddy get off work
Old May 14, 2005 | 11:46 AM
civic94B18B1's Avatar
I agree. I'm in honda pact and we had a student do a cv joint replacement. after driving it for 5 minutes it stopped moving. upon further inspection we found the cv joint was not installed properly and had slipped out of the differential.
Old May 14, 2005 | 11:57 AM
JDMisGOOD's Avatar
Default Re: car does move when in gear? (civic94B18B1)
is that axle popped in all the way?
Old May 14, 2005 | 12:00 PM
Default Re: car does move when in gear? (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">is that axle popped in all the way?</TD></TR></TABLE>
That was one of if not the first suggestion.
Question tho is the axle you have good? the uv joint might be popped out or something along those lines causing it to also not move. Did you check your other axle by chance? Make sure that one is seated properly as well could be that simple.
Old May 14, 2005 | 12:04 PM
t0ekn3e's Avatar
i got a new axle and it not in all the way, but i still have to wait for my buddy to get off work becuase he has my tools
Old May 14, 2005 | 04:15 PM
t0ekn3e's Avatar
ok now it works but there it this whirring noise when i drive what is that?
Old May 14, 2005 | 05:33 PM
turbo_b16_ex's Avatar
maybe throw out bearing. was it makeing that noise before
Old May 14, 2005 | 05:47 PM
92BluEH-3's Avatar
lulz
that wirrr happens to me when i let off if im in first ger but thats because i have a shitty clutch on my car
Old May 14, 2005 | 06:52 PM
t0ekn3e's Avatar
throw out bearing and clutch was replaced a month ago with oem throw out bearing and an exedy organic clutch, it didnt make the sounds before
Old May 14, 2005 | 10:32 PM
t0ekn3e's Avatar
anything?
Old May 15, 2005 | 09:58 AM
um there are so many reasons why it can be whirling. Post your car up on safety jacks and put it in to gear and see if you can track it.
Old May 15, 2005 | 06:44 PM
t0ekn3e's Avatar
ill try that
Torx
Apr 12, 2012 09:11 PM
Kyle244R948
Aug 17, 2009 07:04 PM
vanmaster420
Mar 4, 2007 09:29 PM
g2teg27
Nov 24, 2004 08:53 PM
