exhaust melting rear lip
anyone mounted a rear lip on a coupe with apexi n1 exhaust?? i just paid good money to get mine mounted and painted. and i drove to work today, and the exhaust melted the dam thing right off the car. the only way to drop the exhaust anymore is to make a bracket for it. but its already prety low, cause ive got koni coilovers dropped right down. any help or suggestions??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99b18 »</TD></TR><TR><TD CLASS="quote"> suggestions?? </TD></TR></TABLE>
take the lip off
take the lip off
I would lift the car up a little and bend the exhaust down, or cut some of the exhaust pipe off and reweld it so that the tip sits rite behind the lip
Stick something in the rubber hangers that will drop it down the desired amount. Problem solved--cheap, easy, and effective. Worked for me when my N1 burned my rear bumper on the old Civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel »</TD></TR><TR><TD CLASS="quote">Stick something in the rubber hangers that will drop it down the desired amount. Problem solved--cheap, easy, and effective. Worked for me when my N1 burned my rear bumper on the old Civic.</TD></TR></TABLE>
I did this exact same thing using bushings I found at work. Ghetto but it has worked for two years and no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 112 »</TD></TR><TR><TD CLASS="quote">
I did this exact same thing using bushings I found at work. Ghetto but it has worked for two years and no problems.</TD></TR></TABLE>
Holy mesmerizing avatar!
I also had mine in for about two years before I got rid of the exhaust. Had zero problems with the seutp. I used pieces of hard teflon (secured with zip-ties), but I've read of others using PVC piping, wood
, and bushings, in your case. Whatever works.
Does anybody know the minimum clearance for an exhuast? Is one finger width a good distance. I just installed my cat-back today and was wondering how far from the bumper it should be. I currently have one finger width between my exhuast and bumper. Is there a general rule of thumb distance?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">Does anybody know the minimum clearance for an exhuast? Is one finger width a good distance. I just installed my cat-back today and was wondering how far from the bumper it should be. I currently have one finger width between my exhuast and bumper. Is there a general rule of thumb distance?</TD></TR></TABLE>
A finger gap is fine. When I had a local shop do my custom exhaust when I was turbocharged, the tech only left about a pen's gap between the tip and the bumper. The two never touched, but I constantly checked on it.
I had them redo it when I changed the muffler style and specifically told the guy to leave about 1/4-1/2" clearance this time around.
What about actually under the car? Right where the exhuast bends up then down over the rear control arm it is really close. I would say around 1/4in. Does the pipe really get that hot that far back from the engine? I can see the exhaust, because it slows and traps the hot gases. But the pipe is free flowing. Should I be worried about the under body heating up?
You should be okay although where it goes over the control arms seems kind of close. On all of the exhausts I had on my EJ8, the piping over the LCA had a pretty good amount of clearance. If it's been like this for awhile w/o problems, though, you probably won't have to worry too much.
rMak
Jun 30, 2005 05:04 PM
DV98CVC
18
May 13, 2003 09:13 AM
racecarpete
Aug 4, 2002 08:05 PM
Urban Made 93EX
Jun 13, 2002 06:22 PM
