Injectors aren't injecting any fuel
Old May 13, 2005 | 04:40 PM
dsh7941's Avatar
Default Injectors aren't injecting any fuel
Two days ago at work I'm about to head home and my car won't start. It had been running fine until that afternoon. I see that fuel is making its way to the injectors but it stops there. What could be the problem here. Something electrical possibly? I did have some tranny work done a week prior to this, but I don't know what could have done that cause my problems. Thanks
*David*
Old May 13, 2005 | 05:04 PM
Chiovnidca's Avatar
Default Re: Injectors aren't injecting any fuel (dsh7941)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsh7941 &raquo;</TD></TR><TR><TD CLASS="quote"> I did have some tranny work done a week prior to this, but I don't know what could have done that cause my problems.</TD></TR></TABLE>
Make sure the ground wire connection at the t-stat housing is tight. Have you checked your fuses?
Old May 13, 2005 | 06:23 PM
dsh7941's Avatar
Default Re: Injectors aren't injecting any fuel (Chiovnidca)
Fuses are good and the ground wire is tight.
Modified by dsh7941 at 7:42 PM 5/13/2005
Old May 13, 2005 | 06:51 PM
Chiovnidca's Avatar
Are you getting voltage to the injectors? Does the engine have spark?
Old May 13, 2005 | 07:54 PM
dsh7941's Avatar
I'm not sure if I'm getting voltage to the injectors, but the engine does have spark.
Old Jun 21, 2005 | 07:09 AM
ncskate's Avatar
did u get this problem fixed? because i have spark but no fuel from any of my injectors
Project_DX
Oct 17, 2006 09:32 AM
hondajc19
13
Jan 26, 2006 06:01 AM
shreddinryguy
Jun 26, 2005 01:28 PM
dsh7941
May 13, 2005 04:44 PM
